Home > Td5 > What is this noise?
mustafasoleiman
United Kingdom 2003 Defender 90 Td5 XS CSW Indus Silver
What is this noise?
Hello Forum,
My Defender has started making this whining noise, especially when cold... What do you think is causing it?
Any advise appreciated.
Alex
sorry for the instagram link but I don't know how to post the video otherwise:
https://www.instagram.com/p/CRYmcVyIy6Q/?u..._copy_link http://instagram.com/h4vou/
Post #912654 16th Jul 2021 10:13am
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Power steering pump Roaming around 🇳🇴🇨🇭
Post #912658 16th Jul 2021 10:26am
mustafasoleiman
Thank you... What do i need to do if anything?
A http://instagram.com/h4vou/
Post #912679 16th Jul 2021 12:54pm
Angus_Beef
The whining from the pump would normally occur when there is air in the system. This can happen if the fluid is too low. As the fluid warms and expands, the whining might come to a stop.
Start with checking the fluid level and topping up. If that doesnt do it, then there may be a leak in a seal or a line.
Do you have any leaks or drops on the ground under the car? Roaming around 🇳🇴🇨🇭
Post #912680 16th Jul 2021 1:11pm
Hufflepuff
Wow I thought my pump was noisy, but its nothing compared to that! 2005 Td5 90 XS
1989 V8 110 CSW
Post #912682 16th Jul 2021 1:36pm
mustafasoleiman
Many thanks for the help!
What is the type of fluid I need to buy for a 2003 TD5?
Best
Alex http://instagram.com/h4vou/
Post #912688 16th Jul 2021 2:31pm
mustafasoleiman
Would any of these work?
Post #912689 16th Jul 2021 2:46pm
Dinnu
liqui moly top tec 1200 atf should do the job.
I normally use ATF Dexron III 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #912695 16th Jul 2021 3:16pm
mustafasoleiman
on its way thank you!
a http://instagram.com/h4vou/
Post #912701 16th Jul 2021 3:58pm
