Home > Maintenance & Modifications > MSS rear quarter light window guard fitting - help please
Fellrunner
 2015 Defender 110 Puma 2.2 SW Corris Grey
So it looks like pride does indeed come before a fall, after getting all pleased with myself for fitting the rear door window guard. I’ve now come unstuck with the quarter light guards. I’ve sent a message to MSS too, but thought I’d check here in case anyone can help put me right.
So the issue is that the holes on the brackets on the top of the guards don’t align with the bolts which secure the roof to the body work (which the MSS guards utilise).
I know I’ve got the guards the right way around (left and right).
The attached photo shows the miss match between the roof bolts and the holes in the bracket, which should align.
Thanks for any help.
Post #905739 30th May 2021 4:02pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Post #905745 30th May 2021 4:45pm
Fellrunner
Thanks Chris. I’ve got those, but they don’t help (I understand the instructions), it’s the bracket design which seems to be wrong (I’m wondering if I may have been sent the guards for an earlier model year and thus perhaps different bolt spacing).
Post #905747 30th May 2021 4:51pm
PlumberBoy
2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Hi Fellrunner
Ive just got these guards & got same issues as yourself. What was the outcome of this post ?
Cheers Jon
Post #912201 13th Jul 2021 2:40pm
AMBxx
Not sure if anyone else found a better solution, but I just used a hacksaw and BFI.
Post #912204 13th Jul 2021 3:09pm
PlumberBoy
I shall be returning them if they not correct. As they cost & if not engineered correctly.
Post #912211 13th Jul 2021 3:26pm
geobloke
Hey folks I have had these fitted to my 110 for 8 years or so now. Happy to pop out and get some photos for you...
I do recall the instructions being terrible with this kit.
Thumbs Up
Post #912212 13th Jul 2021 3:26pm
PlumberBoy
Its nothing to do with instructions, the brackets are not correct for bolts. My Defender is a 2009
Post #912217 13th Jul 2021 3:50pm
geobloke
Ah ok. Well here are the guards fitted to my 110… hope they help…
Thumbs Up
Post #912226 13th Jul 2021 4:47pm
PlumberBoy
Hi Geobloke
I can see from your pic the bolt positions & bolt type are different to ours. It appears the guard brackets are correct for your year of Defender.
Ive sussed it out now..these guards do not fit a Puma Defender with seat belts. As the reinforcing bracket for the belts is in the way & also creates different bolt positions.
The guards are too large & bolt holes incorrect.
Post #912233 13th Jul 2021 5:33pm
Fellrunner
So I contacted MSS and was told that the design of the guard hasn’t changed; there’s only one version available and it’s down to the individual to modify to fit their particular Defender.
Post #915576 5th Aug 2021 8:01am
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
It seems that most upgrades require some modification of the new component, or the vehicle, usually both, together with some additional components that you have to buy or fabricate yourself.
Sometimes it's half the fun, sometimes it's a ****** nuisance, and not easy to predict which in advance.
Post #915619 5th Aug 2021 12:37pm
