Home > Puma (Tdci) > I need a favour!! |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 817 |
If you would of asked yesterday I was right where you needed to be.
I’ll get you photos later if nobody else has obliged. I know one goes on the turbo side and another tube goes over the other side of the engine (and the valve is under the wing nearly) Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
11th Jul 2021 5:17pm |
Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 78 |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Here are some photos of my AC pipes and cables. You may notice the turbo is missing right now. |
11th Jul 2021 5:38pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3677 |
Thanks both, very much appreciated.
Kevlar: I assume you have to take the air filter box out to install the pipe from the condenser to the back of the compressor? I’d love to see more, as many angles as possible wouldn be great, especially the point at which the brackets and clips attach. Cheers Col |
11th Jul 2021 5:51pm |
Hi
I can take more pics tomorrow in the mean time this page shows where the brackets go on the pipes https://www.lrworkshop.com/diagrams/land-r...oses_44971 I have never installed AC system mine is factory fitted so not sure about the process. Kev |
11th Jul 2021 5:57pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
I can get a couple of pictures on Tuesday. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
11th Jul 2021 6:08pm |
Thanks Kev. I have the brackets on the hoses, I wanted to know where they attach to the body. Thanks Dinnu, that would be great. |
11th Jul 2021 6:23pm |
Does this help you any? Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
11th Jul 2021 6:27pm |
Great stuff Race.it. Very much appreciated.
11th Jul 2021 7:29pm |
Hi Co1, probably not in order, but here are some photos.
The compressor clutch plugs into the harness, where I am pointing with my finger. If you need any clarification let me know. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
13th Jul 2021 8:08am |
Brilliant Dinnu, much appreciated.
13th Jul 2021 9:45am |
Welcome Co1.
Fyi, my nephew had an AC retrofitted to his Defender, but I do not know what brand. 3rd picture shows a refrigerant line from the dryer that goes to the cabin. In mine, the line passes under the wing, over the windscreen washer reservoir. On his, the line is visible all the way. I think it is more of an assembly error by the ‘professional’ company that installed it. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
13th Jul 2021 10:03am |
