Home > Td5 > TD5 injector woes |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
So which was it, the cover, or the tappets, or the bolts holding down the rocker shaft? The tappet screws are a little dodgy since they are hollow and have a waisted section where the oil feed enters the tappet screw from the rocker arm. It is relatively easy to damage them, especially if you don't realise this. They are also depressingly expensive to replace from what I remember. The cover bolts shouldn't shear unless they've been massively overtightened at some time. Similarly the rocker shaft bolts shouldn't be a problem unless they have been abused at some stage. As it is a TD5, I would also be a little surprised if it had 6 rockers, although I think this may indicate that you are actually referring to the six rocker shaft bolts. |
27th Mar 2021 10:16am |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 270 |
sorry typo on my part.
it was the bolts holding down the rocker shaft Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
27th Mar 2021 1:51pm |
Well this thread was a few months ago now, but...
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge ... Now there is a bit of thread stuck 65mm down a very small hole... The worst of it is that four out of the remaining five bolts still in position fell ridiculously tight. It looks like the garage I had the head gasket done at didn't replace the bolts, used thread lock and some out of this work gorilla strength when tightening down the bolts. What to do folks, what to do... |
10th Jul 2021 4:42pm |
