Home > INEOS Grenadier > Episode 9 Interior Design |
In this day and age, any company that is sending an employee out (as opposed to owner/operators) in either vehicle is going to send them on a training course first; so it's then a question of whether that individual remembers which sub menu, or series of button switches pushes it into "auto" mode, or they look up and flick the diff locks. I know which ones I would want. |
9th Jul 2021 4:22pm |
milesr3 Member Since: 12 Feb 2013 Location: Suffolk Posts: 873 |
Been looking round the one they have on display at Goodwood. The interior, particularly the dash, is awful. It looks like an Amstrad stereo from the 80s.
There are lots of bits and bobs poking out underneath and some flimsy plastic trim, like the rear quarter panels. It doesn’t look the finished article to me. The axles and chassis look serious quality. |
9th Jul 2021 4:26pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
9th Jul 2021 4:27pm |
#1784 Member Since: 11 Nov 2020 Location: Almunge Posts: 45 |
If it's automatic it's automatic, no need to go into menus to activate, just like L663 center and rear diff, they lock up when required even in normal driving mode. Not when someone remembers to push a switch or worse forget to unlock them and breaks an axle on tarmac. I guess it's yet to be seen if Grenadiers diffs are old school hardwired lock/unlock from button/lever or if there is some computer assist involved to protect the driver/vehicle. 110 SE D200 MY21 Tasman blue Discovery 3 V8 HSE MY06 Discovery 1 V8 ES MY97 RRC 2-door V8 MY83 |
9th Jul 2021 4:38pm |
Philip Member Since: 09 Mar 2018 Location: England Posts: 510 |
Very surprised that, if as appears, the centre diff is open unless manually locked.
9th Jul 2021 4:49pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4206 |
I’ll look like a pro next time I use one 2007 110 TDCi Station Wagon XS |
9th Jul 2021 5:08pm |
County V8 Member Since: 07 Jun 2021 Location: UK Posts: 147 |
Is that BMW shifter a LHD one how do you push the button with your left thumb as you would if in a LHD car with your right thumb.
Will there be a RHD one or are all BMWs like that?? Just seen another shot answers that question |
9th Jul 2021 5:14pm |
I wonder how some people manage to get out of bed, washed, dressed and fed to go to work without having to press a few buttons... L663 no longer has a centre diff, and I wonder what the take up rate on the optional rear E diff is? |
9th Jul 2021 5:43pm |
Would that be more or less surprised than finding out the Bowler Wildcat chassis really wasn't made of aluminium... |
9th Jul 2021 5:46pm |
Not this again… |
9th Jul 2021 6:14pm |
The new Bowler CSP chassis isn’t used in the Wildcat. |
9th Jul 2021 6:25pm |
So that's more surprised then...
9th Jul 2021 9:58pm |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 405 |
I have one of those shifters in my auto box 3 Series BMW. Maybe a slightly biomorphic design that works with the curves in BMW interior design language that I agree does not match the rest of the Grenadier aesthetic. Morgan have the same problem in the Plus 6. But to use it is excellent and becomes intuitive very quickly.
10th Jul 2021 6:09am |
Looking for reasons why it would be so expensive to replace and came across these posts on PistonHeads:
"Whilst trivially easy to replace with another CAN enabled lever of your own design, you "can't" because it's rated SAFETY CRITICAL on the FMEA. This is because selecting drive or reverse on an auto causes the vehicle to move, which could crush someone against something or result in the vehicle moving un-expectidly and causing an accident. As a result, the gear level unit will use dual channel redundant CAN and is so incorporated into the powertrain safety matrix that BMW simply won't let you replace it, because that system as a whole has had an absolute fortune in money and tens of thousands of hours of validation done on it. Basically, as per Morgan and everyone else, you use the entire powertrain as supplied or sod off. Those are your two choices...... " and "The FMEA includes the entire system chain, from lever to microswitch to microcontroller to CAN etc You can't change the lever, or change the switches or anything without voiding the safety case, sorry! (the FMEA includes things like the lever jamming, or the switches jamming, or being filled with spliied coffee, going past a radar transmitter at an airport, you name it, the FMEA and validation are, i can tell you, onerous and rigerous. Its a case of use it all, absolutely unchanged, or use none of it)". https://www.pistonheads.com/gassing/topic....0&i=60 |
10th Jul 2021 7:19am |
