![]() | Home > For Sale & Wanted > [Wanted] Series bits |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 866 ![]() ![]() ![]() |
I appreciate this is a little OT but, as many of us on here have Series LRs I'm hoping someone may have the following for sale;
- 109 Canvas and hoodsticks (happy to buy separately or parts thereof) - Hardtop, sides and catflap - 3 Bolt tailgate - Tailgate cappings for rear tub - Rear floor x-members / 109 tub I can use for spares - Glass lens type side lights / indicator assemblies or parts - Sprung type seat bases - Wing mirror heads - Anything else you think may be useful for this; ![]() Click image to enlarge I'm keen to keep the vehicle looking as original as possible so weathered parts are ideal. Also happy to travel or arrange a courier. Many thanks in advance. 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
This type, though I'm not 100% sure if they are correct?
![]() Click image to enlarge ![]() Click image to enlarge 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5889 ![]() ![]() ![]() |
I think the ones i have are different,
Can WhatsApp pics if you want? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
I suspect that when new it would have been fitted with Lucas L488 sidelight units at the front (https://www.holden.co.uk/p/lucas_l488_type_sidelamp_single_contact) and no indicator lights. The indicators when fitted would most likely have been Lucas L549 (https://www.holden.co.uk/p/lucas_l594_type_flasher_lamp_single_contact) which have a glass which has a deeper dome, to make it more visible from side-on angles. When the indicators were fitted the sidelights were moved inboard. The same indicators would have been fitted at the rear.
I think the lights that excossack is describing are the earlier type of military lights (used on, amongst other things, Sankey narrow-track trailers) which have a metal "cup" with a coarse thread fixed to the vehicle, and a glass with four "ears" which screw into the cup. I believe that these are now quite hard to find, especially with the "ears" intact. These are the type shown in the upper photo on this page (http://www.sslawcorp.com/Military-Vehicle-Parts/screw-on-lenses-Military-Lucas-MOD/666383/). The original type of glass was later replaced in military service with the larger type shown in the lower photo on the same page, which fit the same base. I doubt that your fire appliance would have had military pattern lights when built, unless it was originally suppled to the MOD. As mentioned before I think it was a civilian HD spec with HD cooling for stationary running, and as such is most likely to have had standard lighting for the era. |
I have some of the glass screw in ones - two have one ear missing.
and I have the bigger/wider glass ones with the metal band/thread on the lense. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 ![]() ![]() ![]() |
I didn't click on Blackwolf's links but I bought my 488 and 594 lamps from Holdens too. If it's the same now I'd advise spending a bit more and get the ones with metal holders, far better than the cheaper plastic versions.
Great, thanks both! I'll order from Holdens if I can't find any original units. From the 'ring' in the paint around the sidelights it certainly looks as though a larger dia. fitting was previously used. 1985 127 V8 Build Thread
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 ![]() |
I have a plain 109 hardtop and a pair of plain sides (I think the sides are plain, I'd have to go and look they're up at the storage unit). Just off the M6 at Warrington - drop me a PM if any good.
Trebro Member Since: 28 Jan 2016 Location: Hampshire Posts: 241 ![]() ![]() ![]() |
I have a 109 hardtop and cat flap, however the hardtop has period style sliding Windows, easy to change to solid panels on side
Drop me a pm if your still looking |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
There are a couple of 3 bolt tailgates on EBay currently or there was a couple of days ago.
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1386 ![]() ![]() ![]() |
Its worth scouring autojumbles for genuine lenses made from coloured glass. A lot of modern replacements are all clear glass which are coated with respective colour on the inner surface, but which will quickly fade, and look terrible. Euro-Leafing to infinity and beyond.....
Thanks all, a good point there strang, I'll make sure to go to the next one at Malvern. 1985 127 V8 Build Thread
It looks as though the L639 indicators are original fitment (only 2 mounting holes in the wing). So, if anyone has a spare lens and parts (body etc.) please let me know.
