Home > Technical > My 2009 2.4 defender keeps going into limp home mode
Page 2 of 2 <12
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
Check your head gasket with a test kit like this:
https://www.ebay.co.uk/itm/114803385309?ha...SwCOJgmt0h
Since I changed my gasket my overheating and limp mode problem have gone.
Kev
Post #908143 16th Jun 2021 12:38pm
Nitroneil
I had same issue with now sold 110 2.4 urned out to be head gasket. Took the garage a fair time to source the problem Sad 90S D250 fuji and loving it.
Post #908194 16th Jun 2021 5:22pm
Greyman110
I had this with mine too!
I replaced a lot of things but turned out the head gasket was the main cause. Even the RELD chem test was coming back negative when I was trying to diagnose.
Check the top coolant pipes coming from the rad for pressure. If they are rock hard after the engine has started to warm up, thats a sign you'll need to possibly start looking at head gasket.
Post #908250 16th Jun 2021 9:51pm
callummb2
United Kingdom 2009 Defender 90 Puma 2.4 HT Java Black
After doing the injector seals and seats agen it still does it, it only does it on a motor way or due carnage way !, and you can pull over and restart the car agen and its back to full power! whats the vcv valve ? , ill check the oil cap or milky oil and do a lead down test on the coolest sister
Post #910810 5th Jul 2021 11:00am
Greyman110
I’ve been down this road and I know your pain and frustration!
Here’s the thread on mine: https://www.defender2.net/forum/topic75278.html
Everything on my car was fine, except for this one issue which would only happen under hard acceleration. It slowly got worse and I would be able to predict when it would happen. I ran a nanocom so I could see the engine temp which would indicate when it was going to go into limp mode. When it happened it would reset after about 10 seconds and the power would come back on allowing acceleration.
Because everything was fine and tests were negative, I ruled out the head gasket.
In the end I took it to a garage who took the top of the engine off and found it was the head gasket. Interestingly, I was talking to another guy who had the same issue and the RELD test he did was also coming back as negative. His issue also turned out to be head gasket.
I replaced a lot of things that didn’t need replacing. On the plus side I now have a good spares shelf Rolling with laughter
Post #910829 5th Jul 2021 12:47pm
callummb2
HI right iv been on a drive with my snap on scanner plunged in . the temp gage gets up to 90* and stays there, so the head is probably ok. the fuel rail pressure at ideal is 23001 when driving down the road at 60mph it goes between 124633 and and 141232 when it near 14 black smoke comes out the exhures. all this is pointing towards the vcv valve ?
Post #911594 9th Jul 2021 9:37am
spudfan
Ireland
What is the connection between the hard pipes and a possible faulty head gasket? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #911845 11th Jul 2021 12:09am
Greyman110
It’s the gasses getting into the system so indicates a leak from the head gasket (which a RELD test should pick up but clearly not always) or a cracked block as it will leak from the bottom of the engine.
You’ll also find that the system will hold pressure for days so if you opened your coolant cap a couple of days after a drive, you’ll get the hiss.
What I learnt from this was if the engine is on and the pipes go hard with no escape of pressure when its off then its likely there’s an escape from within the engine.
Post #911965 11th Jul 2021 9:15pm
spudfan
Ireland
Thumbs Up 1982 88" 2.25 diesel
Post #911970 11th Jul 2021 10:28pm
Page 2 of 2 <12
