Home > Puma (Tdci) > Changing the radiator
Moffett
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi folks, I have a new rad and intercooler. Is this a massive job? Will I be able to work around the aircon condenser? And have new intercooler pipes too. Any advice would be appreciated.
Post #910217 30th Jun 2021 8:33pm
It's certainly pretty straightforward on a vehicle without aircon, but I've never done it on one with, I'm afraid.
Post #910230 30th Jun 2021 11:23pm
hank
The three 'radiators' are arranged (front to back) air con condenser, intercooler, radiator.
I once fitted just a new intercooler as I expect many have... This is fiddly as the intercooler is sandwiched between the condenser and radiator so you have to pry the two apart and work top down.
If you fit both intercooler and radiator then you will be making life a lot easier for yourself as you can leave the condenser well alone at the front then work front to back fitting the intercooler first (and pipework which pass through notches in the radiator end tanks) then fit the radiator. Pretty simple job for the home mechanic Thumbs Up > 110 XS Double Cab
Post #910244 1st Jul 2021 7:47am
Greyman110
When I did my rad recently, I removed everything (aircon and intercooler). Think you'll end up doing a lot of yanking of pipes so having some room helps.
I don't think I could have done it with the air con condenser in place but that might be down to my level of mechanical expertise Rolling with laughter
You might need new green o-rings for the condenser connections when putting back on.
This also took me way longer than the 2 hours Haynes says it will take! Laughing
I have some pictures of different stages so can PM them if you need.
Post #910254 1st Jul 2021 8:45am
Moffett
I was worried about that, did you recharge the aircon yourself? Pictures would be greatly appreciated!
Post #910302 1st Jul 2021 5:59pm
Greyman110
I was planning on recharging myself but I sent the car in for some work so I didn’t get around to it. I’ll do it when it come la back as I think if will be useful to have the kit as then I can do my other cars.
I’ll pm you tomorrow with some pictures.
Post #910367 1st Jul 2021 10:21pm
Kevlar
Czech Republic 2010 Defender 90 Puma 2.4 SW Santorini Black
I removed my intercooler once without completely removing the AC condenser, It was tight but possible.
It will be much easier job if you remove it but I didn't want to deal with the refrigerant.
Post #910437 2nd Jul 2021 10:18am
