Home > Puma (Tdci) > Drive my 110
Ijk10
Wales 2007 Defender 110 Puma 2.4 CSW Keswick Green
Drive my 110
Anyone local to Newport South Wales willing to drive my 110 and compare the steering to their defender.....driving me mad now...been to 3 different garages who change ball joints and wheel bearings but still feels badðŸ˜
Post #909289 24th Jun 2021 1:42pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
What tyres are you running? If you have mud tyres they are probably the culprit.
Post #909290 24th Jun 2021 1:45pm
Co1
If your stool feels bad your on your own!!
Post #909313 24th Jun 2021 5:08pm
gcc130
Laughing
Post #909315 24th Jun 2021 5:40pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
There are so many ways for a Defender steering to feel strange.
What are the basics? What tyres, and how old are they?
What are the symptoms? Pulling to one side? Under acceleration and under braking? Vibrations?
How old are the shock absorbers (possibly one is defect)? 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MT´s,
Recaro CS´s, anorak, wellingtons
Post #909317 24th Jun 2021 5:52pm
markb110
Panhard Rod bushes sometimes gets missed.
The one closest to the steering box is more obvious to spot if you watch it and someone rocks the steering. The opposite side is harder to spot.
Almost cheaper to replace the whole thing unless you have a friendly garage who will press them out for beer tokens.
SuperPro or similar bushes will enable you to do the job yourself in the future.
If the vehicle has been lifted but the radius arms not replaced with cranked versions you may find that the steering wont return to centre.
And if the above is the case the bushes right behind the axle (not chassis) could be deformed as the camber will be out.
Finally the anti roll bar ball joints may be past their best and dried out. Also easy missed unless removed and checked by hand....
Good luck.
Post #909332 24th Jun 2021 7:34pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Rolling with laughter Rolling with laughter Rolling with laughter Rgds.
Chris
Post #909339 24th Jun 2021 8:06pm
Ijk10
Tyres are continental almost new. Vehicle is totally standard with 70,000 miles.
The issues are..the steering becomes light at around 70mph and feels unsafe. I can feel a click occasionally in the steering wheel like something is snapping. The passenger side feels more positive than the driver side. When going over a small bump in the road it makes a racket. It seems like garages just repair what they see and don't fully investigate the problem. Spent best part of £700 and still the same. Just wanted to see if anyone would drive it and compare theirs...
My stools are fine by the way Rolling with laughter
Post #909344 24th Jun 2021 8:50pm
Pacha
You checked the nut on the steering arm is tight?
I had a similar 'wandering' feel and it had worked loose. Rgds.
Chris
Post #909345 24th Jun 2021 9:01pm
Ijk10
Yes buddy...solid.
Post #909346 24th Jun 2021 9:05pm
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Have you checked the front shock absorbers are tight and the holes have not elongated?
Post #909354 25th Jun 2021 1:09am
Wild Card 90
My bet is on the shock absorbers.
Your description sounds similar to what we experienced about six years ago. The sensation was subtle but had a profound effect. We both started feeling a sort of car-sickness, and couldn´t think why. At first I suspected emission gases creaping into the cabin. Then I heard an occasional noise from the front left.
One of Koni HTR´s had lost oil and had some play.
Climb on the front bumper bar and bounce up and down. See if you sense a difference between the two sides.
Even with uprated springs and stiff Konis, it was obvious once we were looking for it. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #909373 25th Jun 2021 8:02am
hank
I'm in Newport. Happy to have a drive and happy for you to take mine for a spin to compare.
I also know for a few good LR specialists locally Thumbs Up > 110 XS Double Cab
Post #909384 25th Jun 2021 9:47am
jst
check the bracket that holds the lower part of the box to the chassis support.
what are tyre pressures.
so its only at 70mph? not evident at other speeds? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #909391 25th Jun 2021 10:15am
Ijk10
That would be great buddy...could you drop me a message on 07779284901
Ian.
Post #909405 25th Jun 2021 11:41am
