Home > Tdi > Possible 300 Tdi Head. |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1231 |
Which decade do you want it in? Ed
82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
9th Jun 2021 8:32pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10833 |
Will try this one to start with Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
9th Jun 2021 8:46pm |
Well if you want it give me a shout. Ed
10th Jun 2021 11:29am |
Oi - I have two spare, they're conveniently in smaller pieces for reduced shipping costs.
I do have one intact spare crank but it is a V8 one from Nige intended for a table... Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
10th Jun 2021 2:35pm |
Will do and thank you again Ed Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
10th Jun 2021 7:54pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 820 |
P gasket! Mine (300tdi)was using water randomly without trace recently and eventually traced to the P gasket.
It's a poor design fault, mine was leaking when I got it over 5 yrs ago and started again recently so this time I replaced the metal gasket with a diy cut card gasket and so far so good. Worth trying before you start ripping heads off? |
11th Jun 2021 9:53pm |
Sorry a bit late with the reply, but it's not the P gasket as she is consistently drinking water more now and it seems to be the same symptoms as when the original head cracked in three places Clayton.
18th Jun 2021 8:25pm |
So the outcome to this thread is on page 51, here
https://www.defender2.net/forum/topic57447.html Thank you for all your reply's, very much appreciated Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
23rd Jun 2021 7:24pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5215 |
i would look at sending the head away to checked etc, to see why its failed. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
1st Jul 2021 6:52pm |
I was going to send it away to be tested but my indy showed what he suspected and took the exhaust valve out as it had some rusty water marks around the edge of it and he found a crack in the head by the shaft were the valve stem goes through Clayton.
1st Jul 2021 8:07pm |
My rover metros vvc engine started to blow from the exhaust side of the head gasket, and that was down to, who ever assembled the head back on the car, They had decided to use a early generation head gasket. They had spent a few quid on getting the head ported and polished but decided skimp on that. I recon to this day, it was just a odd ball special, that was built up to get a car on the road. Because when me and my dad, did the head gasket on it, we found one of the pistons looking very black. So who ever is running around in that engine, will have a bit of a surprise at some point Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
2nd Aug 2021 11:08pm |
Clayton.
4th Aug 2021 8:06pm |
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 363 |
i've just replaced my head with a turner. The old one will need lapping but it's for sale if anyone wants it. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
27th Sep 2021 3:29pm |
