Home > Technical > challenge defender/range rover
defendertom
Wales 2011 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
hi i have bought an unfinished 100 inch range rover defender. all i have is chassis and 200tdi engine, im looking for ideas. what axles gear box should i use? do i bother with air lockers or keep standard diff and sharts. if anyone can help i would be greatful. thanks svx tdci (project)
200tdi 90
90 tdci truck cab
90 TD5 green lane
200tdi 100inch trayback
Post #90873 23rd Sep 2011 3:48pm
markb110
Hi
I guess that the first thing that you need to decide is how you want to use your new project. No point buying things that you won't use.
Have you seen the vehicle builds on the Devon 4x4 website. These cover challenge trucks, green laners and travel.
The write ups and pictures are pretty good
Good luck
Mark Thumbs Up
Post #90890 23rd Sep 2011 4:43pm
markb110
Hi
Good luck
Mark Thumbs Up
Post #90891 23rd Sep 2011 4:43pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
if your going challenge route then an auto box is the way to go.
did my convertion about 4 years ago. lifted 3.5efi + 4 speed auto straight from range rover and put in a 90
truck cab. best mod i've did to truck lockers great if you do need them but a good set of tyres first.
again if for challenges then it needs to be 3 winches. alot of folk going the hydrualic route now, whatever winches don't scimp. buy the best you can afford the first time.
am hoping to build new offroader soon myself.
good luck what ever way you go
steve 110 xs s/wagon
s3 swb soft top
Post #90958 23rd Sep 2011 8:12pm
wslr
It's the http://www.de-cidertrophy.co.uk weekend. Smile
Been pushed into sponsoring these reprobates with this 300tdi winch challenge vehicle.
[/img]
Post #90968 23rd Sep 2011 8:36pm
BigRuss
I think it was Mark Williams who did a build of a 100" hybrid on the discovery channel a few years ago. You can buy the build on DVD. It'll give you a few good ideas and might help you decide what you would like to do different.
Russ Russell
2011MY 110 XS USW Black
Post #91016 24th Sep 2011 7:17am
roel
If you want to go serious off-road like challenges.
as you don't have axles yet look for some Toyota LC80 axles with lockers. They are strong and 2" wider then LR axles, lower diff ratio so compesates for bigger tyres. I know I dropped some dirty words here but I see this happening in The Netherlands and it looks like it is the way to go.
The a good set off LC80 axles are probaly cheaper then getting LR axles and start shopping with Ashcroft to beef them up to make almost the same strengt as LC80 axles.
Antother option is Volvo Portal axles but they are expensive.
Gearbox hmm. Autogearbox has some advantages but manual gearboxes too. I am going manual at the moment. Specially if you want to keep the 200 tdi. If you go for a V8 a auto might be the way to go.
Don't make it to high. Sometimes you see very much lifted vehicles. I think 2 or 3 inch lift is enough, you drag the axles through the mud anyway. If you need more space for the tyres just change the body to fit. Roel
2003 90 Td5 (2009-now)
Post #91033 24th Sep 2011 8:36am
T1G UP
get over to devon 4x4 forum...there more set up for off roading than these set of OCD car cleaners on here! Rolling with laughter
Post #91034 24th Sep 2011 8:39am
Mo Murphy
Rolling with laughter The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey
Post #91079 24th Sep 2011 1:57pm
Happyoldgit
Laughing Steve.
http://forums.lr4x4.com
Post #91112 24th Sep 2011 5:46pm
TJ101
Russ
Now , that was a standard joke at the time,, walk into scrap iron when they were trading, get the cheque book out, and bolt it all on !!!! Rolling with laughter
First job, is find the events you want to do, check their class's etc, and go from there
If it was me,, start standard class, IE only one aid to traction, that being a front winch,, build the car, (cage, tyres, suspension, underside protection etc) and do a few events, to see if you enjoy it ??
You can then move on, and develop the car as you go,, triple winches, overvolting, F & R Lockers, HD shafts and CV's, autobox, under-drive, 36" tyres etc etc
Forget the autobox on a 200 !! need more guts,, TD5, TGV, or a proper engine,, = V8
Their are a few forums, devoted to comp events etc Whistle California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #91116 24th Sep 2011 6:10pm
