Home > Puma (Tdci) > My clutch and gearbox |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
Im nearly in the same boat, but less the leaks.
Definitely do an upgraded output shaft. Ashcroft or LOF. Im going with LOF. Others prefer Ashcroft. Pick what seems best to you. There are options on clutches as well. I doubt anyone would recommend the standard factory clutch. Options include, LOF, Clutchfix, and the 4x4 Transit clutch. Probalby some others. I'll probably go for the LOF RoadSpec on my tuned 2.2, but may opt for the new tdci powerspec. Good luck! Roaming around 🇳🇴🇨🇠|
21st Jun 2021 4:09pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17374 |
The latest genuine clutches are massively better than the early ones (my current one has done 100k miles but it now pretty shot). As noted above, there are many options.
If it was me I would fit an upgraded clutch (my preference is the Transit 4x4 for no particular reason), a genuine current spec slave cylinder, and new genuine limiting valve. For the output adaptor shaft, I would inspect it, and if it appears worn replace with and Ashcroft "wet" shaft. If however it isn't worn in 60k miles, I would grease it generously with molybdenum grease (eg. CV joint grease) and reassemble. If your coupling isn't wearing it doesn't need replacing, just greasing. If it is wearing, replace it. |
21st Jun 2021 5:31pm |
