![]() | Home > Td5 > SOLVED - TD5 DEFENDER - NO POWER - NO SMOKE AFTER REBUILD |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
Suggest you check turbo. Check inlet maybe a shop rag is in there stopping the turbo as it is blocked or its is seized. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 ![]() ![]() ![]() |
Also check turbo waste gate isn't seized (open and meaning no pressure, or closed meaning over pressure and ecu cuts fuel) and actuator spring is still good.
As you have a Hawkeye, what is your max turbo pressure you see if you accelerate from 1500 to max rpm in 3rd gear? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
atakanmerdin Member Since: 15 Dec 2017 Location: Nairobi Posts: 26 ![]() ![]() |
Thanks for replies.
Turbo Boost nominal and wastegate free, would be black smoke if fuel and no air actually have had a rag in my inlet manifold once! Anyway problem solved by swapping out injectors, i asked if they had tried to clean injectors and was told the used a steel wire brush, swapped them and the car is ALIVE! Ill slowly test the injectors one by one to actually determine if all 5 dead |
