Home > Td5 > SOLVED - TD5 DEFENDER - NO POWER - NO SMOKE AFTER REBUILD
atakanmerdin
Kenya
HALLO!
I've got a tricky one for you guys!
Friend showed up in his very nicely setup defender 110, got everything going for it except NO POWER
Background:
Defender 2006
15p
Engine had quite a bit of blow-by and was rebuilt by a shop close to them, the same guys rebuilt a td5 of one of their disco 2s and t goes well years later. Same exact mechanic.
Car is Gutless and has little to no smoke out the exhaust.
These are bits we have looked at/swapped
1. Fuel pump genuine good VDO
2. MAF sensor genuine good VDO
3. FPR new unit
4. Fuel filter new
5. MAP/AAP/MAF readings on Hawkeye within spec
6. Only error registered is tacho overdrive (if ABS FITTED) The TPS readings on HAWKEYE are within spec
7. Injector plunge set correctly, New washers and O rings too
8. EGR blanked
9. Silicon hoses all round
10. No oil in injector loom or ECU
Turbo pulled well before rebuild.
The fact that it has little to no black smoke puzzles me as most sensor related issues or even lack of boost would usually cause black smoke, unburnt diesel etc.
This car seems like it gets no fuel. Injector balance is -1 to +2, ecu tests for them positive as they all click! And they are correctly coded.
We even tried a different well working ECU (coded in properly)
Could this be a timing issue? Not enough advance? Injector pulse duration too low? I'm baffled!
The car has a BAS MAP and a writing module, it behaves the same way with the stock map the stage 1 and stage 2 maps.
Post #907401 11th Jun 2021 12:13pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Suggest you check turbo. Check inlet maybe a shop rag is in there stopping the turbo as it is blocked or its is seized. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #907449 11th Jun 2021 6:33pm
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Also check turbo waste gate isn't seized (open and meaning no pressure, or closed meaning over pressure and ecu cuts fuel) and actuator spring is still good.
Post #907462 11th Jun 2021 7:37pm
roel
As you have a Hawkeye, what is your max turbo pressure you see if you accelerate from 1500 to max rpm in 3rd gear? Roel
2003 90 Td5 (2009-now)
Post #907563 12th Jun 2021 5:40pm
atakanmerdin
Kenya
SOLVED
Thanks for replies.
Turbo Boost nominal and wastegate free, would be black smoke if fuel and no air actually have had a rag in my inlet manifold once!
Anyway problem solved by swapping out injectors, i asked if they had tried to clean injectors and was told the used a steel wire brush, swapped them and the car is ALIVE!
Ill slowly test the injectors one by one to actually determine if all 5 dead
Post #907736 14th Jun 2021 8:15am
