Home > Technical > Factory Alarm...locking with windows open? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17207 |
Lock the car using the key in the driver's door. The alarm will be set but without the volumetric sensor being turned on. Unlock in the usual way (plip) or you'll set the alarm off.
An alternative some folk do is to pop the volumetric sensor off the headlining and unplug one of the wires, thereby disabling it. I find that the proper method (key in door) works best. |
11th Jun 2021 8:46pm |
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 152 |
Not sure how widely it applies but on both my TD5 and Puma- leave driver's door open; press 'lock' button on remote fob; horn sounds, briefly (signifying disarm of sensors); close door. Cheers, Guy.
11th Jun 2021 9:23pm |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
Thanks both, will give it a try
11th Jun 2021 10:06pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5570 |
PM’d you
11th Jun 2021 10:35pm |
Really? That is not how it should work. If the driver's handbook is to be believed, if you do this the volumetric sensor will be disabled until the moment you shut the door properly, then will arm. This is the "approved" method: |
11th Jun 2021 10:54pm |
Following @blackwolf post I've had a look at my (2014) TDCi handbook and it clearly doesn't cover anything about arming the alarm without the volumetric sensors. I think the door thing my post referred to was set out in my TD5 manual but could be mistaken. I think @blackwolf may have been referring to it in an old thread https://www.defender2.net/forum/topic5817-15.html
Click image to enlarge Cheers, Guy. |
12th Jun 2021 8:47pm |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 400 |
I would have said blackwolf's approach was correct, key in door, that is certainly how the older Discoverys worked and they used the same alarm ECU.
My Puma doesn't have an alarm and is rarely locked, so can't say for sure! --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
13th Jun 2021 11:42am |
Key in door works so thanks all.
15th Jun 2021 10:22pm |
