![]() | Home > Camping, Caravanning and Holidays > Roof tent size advice required |
I'm pretty sure it's only 1.8m wide over the wheel arches and it's a lot narrower at roof level. 'Wide' roof tents are typically around 1400mm.
The very wide Stargazers are designed to be mounted so that they open over the side of the vehicle rather than the rear, so a 2.4m version takes up about 2.6m of roof length when packed. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 ![]() ![]() |
From what you've written you're transposing width and length...?
I've not seen one, but if they're any "wider" than 1.4m closed, then they open sideways, not rearwards. So your 1.8m example would be 1.8m lengthways down the vehicle when closed, and open put sideways to the full 2.4m length. My 1.8m tufftrek TTO2 certainly wouldn't fit to open over the rear. Too wide as you say. But a 1.4m tent will fit sideways on a rack just fine. Edit.... That makes your 2.4m long tent then 1.2m of vehicle width when closed. And the width you choose is then just the length down the vehicle of rack space you want to take up. |
s55shh Member Since: 30 Dec 2019 Location: staffs Posts: 193 ![]() ![]() |
yes I spotted this now. They have packed dimensions which make more sense. Anyone got a discount code?
Smyles_ Member Since: 25 Aug 2018 Location: Copenhagen Posts: 517 ![]() ![]() |
Have any children that are Uni students, or know of any...?
![]() Be amazed the number of companies that'll offer student discount if you ask... just make sure you can get yourself a hold of Uni ID card like mine. Stuart ![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
j17 Member Since: 20 Jan 2019 Location: West Midlands Posts: 59 ![]() ![]() |
We have just had the stargazer 2.4 and used last week for the first time
It’s big and very heavy, you really need 2 people to set it up Tent easily sleeps 4, there is framework in the middle The width is fine, I got a locker box made up for front and this means I have an overhang on rear but fits ok We bought the annexe too but it’s too big and heavy for us so I’m probably going to sell it ![]() ![]() Click image to enlarge Jit Instagram @magars_on_tour |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1364 ![]() ![]() |
![]() ![]() Click image to enlarge We have a 2.4 Hm and i used to have a tuff trek 1.8 ![]() Click image to enlarge |
I have the annex too, whilst it is a little heavy it's perfect for using as a changing room for the family when set up for more than a day. i don't fit it when it's on the roof rack but when using the trailer i fit it every time. with regards to setting the tent up, i have mastered doing it on my own and can get it done pretty quickly now. i'll try find some pictures of mine set up so you can see |
https://www.defender2.net/forum/topic62136.html
few of the trailer there |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
2.4 long is the set up length so it'll be 1.2 wide when folded away. The other dimension is the width, a 1.2 and a 1.4 suit well being set up over the tailgate, but others work well set up over the sides. i would suggest having a look at the Tuff Trek range, the seem to be good and a good company to deal with. |
Great setup there AJC
I actually read a bit of your build thread when I was working out how to make a slide out fridge/kitchen ![]() Click image to enlarge ![]() Click image to enlarge Jit Instagram @magars_on_tour |
which roof rack is that btw?
mine is flatdog Jit
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 496 ![]() ![]() ![]() |
I recommend the Thule bars fitting exactly an a Defender roof With those I'm @ 2,40m which saves money on a boat. If you use it as a couple, the 140 cm width will be bit tiny (especially for clothes \ items inside while sleeping) |
