Home > Camping, Caravanning and Holidays > Roof tent size advice required
s55shh
Looking at a Howling Moon Star Gazer for my 2015 110. They are all the same (2.4m) length but widths vary. Seeing as the 110 is 1.8m wide wouldn't is be a problem going for the 2.0m or 2.4m wide tents re overhanging? I fancy as much room as possible but not sure about the wide load!
Anyone got any thoughts on alternatives or best place to purchase? Forum discounts? Need a flat roof rack too.
Post #906640 6th Jun 2021 10:58am
I'm pretty sure it's only 1.8m wide over the wheel arches and it's a lot narrower at roof level. 'Wide' roof tents are typically around 1400mm.
The very wide Stargazers are designed to be mounted so that they open over the side of the vehicle rather than the rear, so a 2.4m version takes up about 2.6m of roof length when packed. Darren
Post #906648 6th Jun 2021 12:08pm
Matt110
From what you've written you're transposing width and length...?
I've not seen one, but if they're any "wider" than 1.4m closed, then they open sideways, not rearwards.
So your 1.8m example would be 1.8m lengthways down the vehicle when closed, and open put sideways to the full 2.4m length.
My 1.8m tufftrek TTO2 certainly wouldn't fit to open over the rear. Too wide as you say. But a 1.4m tent will fit sideways on a rack just fine.
Edit.... That makes your 2.4m long tent then 1.2m of vehicle width when closed. And the width you choose is then just the length down the vehicle of rack space you want to take up.
Post #906664 6th Jun 2021 3:04pm
s55shh
yes I spotted this now. They have packed dimensions which make more sense. Anyone got a discount code?
Post #906665 6th Jun 2021 3:14pm
Smyles_
Denmark
Have any children that are Uni students, or know of any...? Whistle
Be amazed the number of companies that'll offer student discount if you ask... just make sure you can get yourself a hold of Uni ID card like mine. Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #907277 10th Jun 2021 5:24pm
j17
We have just had the stargazer 2.4 and used last week for the first time
It’s big and very heavy, you really need 2 people to set it up
Tent easily sleeps 4, there is framework in the middle
The width is fine, I got a locker box made up for front and this means I have an overhang on rear but fits ok
We bought the annexe too but it’s too big and heavy for us so I’m probably going to sell it
 Jit
Instagram @magars_on_tour
Post #907328 10th Jun 2021 10:09pm
AJC
We have a 2.4 Hm and i used to have a tuff trek 1.8
Post #907348 11th Jun 2021 7:24am
AJC
I have the annex too, whilst it is a little heavy it's perfect for using as a changing room for the family when set up for more than a day. i don't fit it when it's on the roof rack but when using the trailer i fit it every time.
with regards to setting the tent up, i have mastered doing it on my own and can get it done pretty quickly now. i'll try find some pictures of mine set up so you can see
Post #907349 11th Jun 2021 7:27am
AJC
Post #907350 11th Jun 2021 7:31am
AJC
Post #907353 11th Jun 2021 7:39am
AJC
Re: Roof tent size advice required
2.4 long is the set up length so it'll be 1.2 wide when folded away.
The other dimension is the width, a 1.2 and a 1.4 suit well being set up over the tailgate, but others work well set up over the sides. i would suggest having a look at the Tuff Trek range, the seem to be good and a good company to deal with.
Post #907356 11th Jun 2021 7:42am
j17
Great setup there AJC
I actually read a bit of your build thread when I was working out how to make a slide out fridge/kitchen
 Jit
Post #907384 11th Jun 2021 10:06am
s55shh
which roof rack is that btw?
Post #907418 11th Jun 2021 2:43pm
j17
mine is flatdog Jit
Post #907422 11th Jun 2021 2:53pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
I recommend the Thule bars fitting exactly an a Defender roof
With those I'm @ 2,40m which saves money on a boat.
If you use it as a couple, the 140 cm width will be bit tiny (especially for clothes \ items inside while sleeping)
Post #908991 22nd Jun 2021 6:49pm
