![]() | Home > Off Topic > Damage? |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
Thanks for that. The tyres have no flat spots, I don't think my wife applied the brakes - if she had I doubt the car would have stayed in a straightline whilst being pushed so far backwards by a tow bar / ball which impacted slightly off centre. She was battling to not be pushed sideways / off the road.
I spoke to VW this morning and they said, hard to tell, I'd drain the box and see if there is debris..... Let's see what A plan have to say - I've had to email them as the call centre is seemingly v busy. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17603 ![]() ![]() ![]() |
I'd be very surprised indeed if "significant" wear occurred in a 50m pushback; in fact I'd be surprised if it did any damage to the transmission at all. Nasty experience though, it is disturbing that we allow people like that to share our roads society. |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
If it was in gear and pushed backwards then there is no way that the engine would still be running unless the clutch was 'depressed', the wheels locked or the box in reverse.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
^^^ OP says it's an auto and was in "D".
yes in 'D' but it is a DSG gearbox so closer to a manual than an auto. No slipping torque converter.
nicam Member Since: 14 Dec 2007 Location: deepest Lancashire Posts: 157 ![]() ![]() |
Quite correct - no way to check - even if you have a Ferrari Formula 1 pit crew available to strip, check and rebuild everything - just ask Charles Leclerc. It can still break. Don`t drive faster than your angel can fly! |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 ![]() ![]() |
Agree with this... confused as to how it could generate any damage whatsoever. The engine was running at the end of the event, thus the clutches weren't engaged. The transmission is capable of being driven backwards, that's just overrun braking, which a DSG clutched based system is engineered for, and it's capable of doing that for many many thousands of miles over it's lifetime, slowing the vehicle by transmission rather than braking. But in this case, it wasn't even in any stress as with the vehicle stationary, the clutches aren't engaged. It's just rotating freely moving gear sets backwards, with an open DSG clutch system idling and clear. Put another way - a comparable situation would be that you've simply generated a condition whereby you've rolled to a stop on a hill, and allowed the vehicle to roll backwards down the hill by 50m. Can't see anything wrong with that other than a bit of clutch wear, but they're designed to cope with generating creep torque similar to a torque converter anyway, so should be fine. By definition the gears transfer torque in both directions - but weren't needing to in this scenario. Whether the transmission is in drive or reverse - can't see the effect. You could also put the vehicle in reverse, reverse up your steep drive, and then allow the vehicle to coast back down to the ground again without applying the throttle. No damage would occur, even if you suddenly applied throttle halfway through that roll... sure the clutches would be engaged and would wear a tiny amount as per a heavy hill type pull away. But I don't think that it could be damaged. Horrific experience, and really feel for the OP and family, really hope you get some closure on it and that the car is OK - not that the car in this instance is the most important thing but ironically seeing it repaired and fixed often allows people to move on. I had the same with a major accident my wife had a few years ago. All the best. |
Thanks chaps. I had a call from the body repair place today to say the insurance company is writing it off. I’m waiting to hear the details. It was £11,750 when I bought it from VW in Oct 20... so no doubt it is worth £2.50 now. We will see.
I’d like to replace it with something my daughter can learn in and then have as a first car when she is 17 in spring. |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5236 ![]() ![]() |
How old its it? for a 11k car to be written off, that is just silly! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Hey Procta, it is a 64 plate and had 50k miles on when I bought it. A well equipped 1.4TSI GT (150). I’m surprised too!
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2138 ![]() ![]() |
Worth noting to never take the insurance companies first offer before checking real prices in the market as they generally offer a low “book” value.. Look online for same vehicle , same spec, same mileage, history etc from a dealer. Screen grab details and book mark a few that are the same as yours before the incident . This will give you a good idea of value and really help negotiate the value of the insurance payout if they offer below the value you think the vehicle should be valued at. |
Thanks. I shared the purchase price with the insurance company when I emailed the claim details so they know the starting point. I could do without the admin burden but the girls are fine and it’s only metal.
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2051 ![]() ![]() |
I managed to smash my wife’s 1.6 Golf GT back in February 2020.
![]() ![]() It was written off. ![]() If remember correctly I think I got £11500 from the insurance at the time. ![]() Click image to enlarge |
Christ its only 5 and half to 6 years old, and they are writing it off! Ok if it had another 2 years on it, id have said fair play. Sure to christ the damage done, would under the 3k market, and that's going by the a coach works repair. The car will be worth about 7 to 8k, if you sold it on! Are insurances not interested in repairing cars anymore like? ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
