![]() | Home > 130 > Passing cabin connection to cargo bay 130 |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 337 ![]() ![]() ![]() |
Ok, that's alright then. All the best with the build! Defender 130 HCPU Td5 MY2000
mopadzi Member Since: 24 Sep 2013 Location: orlickoustecko Posts: 41 ![]() ![]() |
Hello, everyone, our construction continues. We're in a phase right before the auto assembly.
![]() Click image to enlarge ![]() Click image to enlarge |
Interframes ready. They are strong enough with high torsional stiffness to avoid cracking the claws of the housing superstructure while driving in the field and crunching the base chassis of the car.
We used the original Def130 rear window frame to connect the cabin to the living space. The two frames will be connected in axis against each other by a flexible blade. This will provide permanent emergency access between the two parts of the car.
Smyles_ Member Since: 25 Aug 2018 Location: Copenhagen Posts: 518 ![]() ![]() |
This is so very very cool!
Appreciate you keeping us up to date. Some nice custom fabrication work there ![]() ![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10857 ![]() ![]() |
+1
Hello, everyone, we finally have a residential extension on the car. However, there is still a lot of work to be done with the integration of the superstructure with the car and the interior of the residential superstructure itself.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Wow
![]() That looks absolutely fantastic ![]() I like how you've also managed to integrate an external roll cage in there too. Top work. ![]() ![]() Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
Very thanks
Very thanks
