Home > 130 > Passing cabin connection to cargo bay 130 |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 337 |
Ok, that's alright then. All the best with the build! Defender 130 HCPU Td5 MY2000
2nd Mar 2021 8:31pm |
mopadzi Member Since: 24 Sep 2013 Location: orlickoustecko Posts: 41 |
Hello, everyone, our construction continues. We're in a phase right before the auto assembly.
25th May 2021 9:21am |
Interframes ready. They are strong enough with high torsional stiffness to avoid cracking the claws of the housing superstructure while driving in the field and crunching the base chassis of the car.
25th May 2021 9:29am |
We used the original Def130 rear window frame to connect the cabin to the living space. The two frames will be connected in axis against each other by a flexible blade. This will provide permanent emergency access between the two parts of the car.
25th May 2021 9:38am |
Smyles_ Member Since: 25 Aug 2018 Location: Copenhagen Posts: 518 |
This is so very very cool!
Appreciate you keeping us up to date. Some nice custom fabrication work there Stuart Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
25th May 2021 10:16am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10857 |
+1 Clayton.
25th May 2021 8:19pm |
Hello, everyone, we finally have a residential extension on the car. However, there is still a lot of work to be done with the integration of the superstructure with the car and the interior of the residential superstructure itself.
Click image to enlarge Click image to enlarge Click image to enlarge |
10th Jun 2021 11:20am |
10th Jun 2021 11:21am |
Wow
That looks absolutely fantastic I like how you've also managed to integrate an external roll cage in there too. Top work. Stuart Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
10th Jun 2021 11:46am |
Very thanks
10th Jun 2021 11:51am |
Very thanks
10th Jun 2021 11:52am |
