Home > General & Technical (L663) > Defender XS EDITION |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 |
Has anybody on here taken delivery of an XS EDITION new Defender? I'm trying to find out if it is possible to add the adaptive cruise control to one as for some strange reason it isn't offered as an extra. I spoke with the guy from JLR retrofits but he needs an XS EDITION chassis number before he can tell me whether this can be 'switched on' Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
8th Jun 2021 9:11pm |
pjm-84 Member Since: 12 Apr 2021 Location: Hampshire Posts: 666 |
Way too early. Looking like September for the XS
8th Jun 2021 9:15pm |
OK thanks, I did think they had just been announced but I read on Facebook that somebody had seen one in the flesh so it got me thinking Cheers Ian
8th Jun 2021 9:27pm |
Cheers, I've had a D250 SE this week on an extended test drive and think I may change from the XS. The SE with a few options seems to be better bet for me atm, although I think I've got 100's of builds saved from the configurator I may also opt for the D200 instead of the D250, the only difference I can see is the -50BHP and a slightly slower 0-60 time which doesn't really bother me at all, oh and the D200 is about £3500 cheaper! That's a lot of money for 50BHP Cheers Ian
9th Jun 2021 5:39pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 |
Tell me about it, my salesman asked for my build I said pick a number between 1 and 1 million and LR complicated things more by delaying the 90 so my 20MY spec was no good so we had to go through it all again.
I can’t fault the D200 so far and I don’t feel I’ve got £3.5k less of a car. As you say it’s a lot of cash for 50 horses and 70Nm of extra torque. 24MY 90 D250 HSE, Tasman Blue |
9th Jun 2021 6:55pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2688 |
D200 is perfect. Near enough the power and torque of my old one and a 50% safety margin built in to the engine design.
Plus if you’re so inclined there are companies that will put the factory D250 or D300 map on for you for a couple of hundred quid - saving you a fortune. |
9th Jun 2021 7:05pm |
For me its about the P400.... hence the XS option. The X version would be another £18k so doesnt stack up. However if I was going with diesel I would be looking at the D200 |
9th Jun 2021 8:34pm |
Og250 Member Since: 18 Feb 2021 Location: Sussex Posts: 45 |
Not yet - mine is apparently built, but not yet released (no sure what that means). So I am guessing the earliest for me will be end of July, the latest is anyone's guess...
10th Jun 2021 8:16am |
oop north Member Since: 23 Mar 2016 Location: Preston-ish Posts: 59 |
This may be my imagination, but I am convinced that the XS colour choice has changed in the last few days in the configurator. I am sure the standard colours were black, silver and grey (sure because I m bored of monotony which frustrated me!), but the grey has now been replaced with the bronze colour (the one my children would call poo brown if I got one). Silicon silver is also still available for extra money
10th Jun 2021 9:23pm |
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 270 |
No they haven’t changed , I’ve been looking at them for a while as I fancy a XS. My only gripe is the lack of Adaptive cruise control, which I have on my present car. Just hope that Mo at LR retrofits can configure on a XS
10th Jun 2021 9:33pm |
Ah - must have just ignored the Gondwana then on the grounds I know what my daughters would say
10th Jun 2021 10:19pm |
I've decided to go with a Defender D200 SE instead, I placed my order yesterday and have put a thread in the orders section of the site with all the options I've chosen
https://www.defender2.net/forum/post907427.html#907427 Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
11th Jun 2021 3:47pm |
Mark1107 Member Since: 19 Oct 2020 Location: Los Angeles Posts: 74 |
Trust me...if Mo can add the WiFi hotspot and the torque vectoring electronic rear differential as an oem spec, he can add adaptive cruise. All 2020’s have the adaptive cruise hardware even if it isn’t turned on, idk about 21 or 22 models, but you can easily buy the hardware and Mo can turn it on if it doesn’t come with it.
2022 Defender Trek Competition 110 collectors edition! 2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold) 2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair 2014 Range Rover L405 Autobiography Full Size Aintree Green 2014 Dodge Viper GTS Stryker Green |
13th Jun 2021 5:04am |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
IIRC in one of their many videos Powerfuluk found that their 110 S had all the kit for Adaptive Cruise, they only needed to enable it using their fault finding tool. The sensor for it is behind the green oval badge on the front grille. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
13th Jun 2021 5:31am |
