![]() | Home > Modifications & Maintenance (L663) > Rear Cargo Rack D90 ( Hardtop) |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2653 ![]() ![]() ![]() |
Looks good, definitely go for it
I've seen them when i have been in the States and really liked the idea so i designed my own version for the back of my HT 90. The tray has mounts bolted to the tub and is held in by a spring bolt in each corner. This means it is very easily removed when i need the full space back. It has two grey Euro boxes underneath but was originally designed to have the spare wheel under it when i was competing. Having the spare over the rear axle stopped the pendulum effect when transitioning from a muddy track to 90 degree turn onto tarmac. The inner dimensions will carry two Really Useful Boxes side by side or four stacked and held in place by the cargo net. Also when competing or simply going away for the weekend then the tray is used to separate items to keep personal gear up higher and kept clean. Its one of my favourite mods. ![]() Click image to enlarge ![]() Click image to enlarge |
My inspiration
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 434 ![]() ![]() |
Picking up this project.
First I needed to make sturdy brackets / attachpoints. Bracket formed and mounted with self-tapping screws and PU body kit ![]() Click image to enlarge ![]() Click image to enlarge After ![]() Click image to enlarge ![]() Click image to enlarge Bought on Amazon an Interior Cargo Rack ( not my first choice, first post above shows the Body Armor 4x4) https://www.amazon.de/dp/B09KRV4PWP/ref=re...asin_title Now I have to make another extended mounting bracket and little cutting in the edges. ![]() Click image to enlarge To be continued.. No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
