Home > In Car Electronics > Recommendations for a mirror with built in screen.
Matt110
Would quite like a reversing camera mirror... One of the ones that clips to the front of the mirror and has a hidden screen?
Don't need it to do dash cam features... There's an app for that! (Well... I use an app anyway).
Just need a mirror, and a screen when the input is turned on.
Recommendations and whether or not they're actually any good appreciated.
Thanks.[/i]
Post #905632 29th May 2021 5:08pm
Dinnu
I bought one from china....does the job, but can remark the following:
1. If you have an early/evening sun direct into the windshield, hard to see.
2. The smallest I could find at cheap price is bit long, that fouls with the sunshades. Defender sunshades are huge as well!!!
3. It blocks a bit too much from the field of view (centre portion of the windshield).
4. The defender rear view camera ball socket is not very tight, and can drop by the slightest add on weight. I had to put some thread lock in the ball socket. That expanded a bit and made it tighter.
For what I paid, it has been very good. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #905636 29th May 2021 5:43pm
Matt110
Thanks for the thoughts. They seem pretty big limitations of them especially the size bit Vs the mirrors.
It just seemed a really neat way of getting a screen without sticking a big thing on the dash I guess.
I guess the Chinese ones are pretty good value could give it a go.
Post #905643 29th May 2021 6:53pm
Dinnu
Here is my setup.
Post #905789 31st May 2021 5:29am
blackrock
United Kingdom 2012 Defender 110 Puma 2.2 SW Firenze Red
I'm also trying one of these 'screen mirrors' and had the dropping problem due to the loose ball. I also get a lot of vibration when moving which make the image in the mirror 'non optimal'. Did you have that problem wit yours? The fixings that came with mine are like rubber bungees that attach around the original mirror, did you have those fixings?
Andrew
Post #959202 22nd Jul 2022 4:39pm
Dinnu
Only 2 days ago there was another post on droopy rear view mirror!
https://www.defender2.net/forum/topic84298.html
Never had or noticed a vibration issue. Only use it when parking in tight spaces or hitching a trailer.
Mine is with ‘clamps’ with internal springs that clamp on to the original mirror.
Been good for over 2 years now. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #959204 22nd Jul 2022 4:50pm
blackrock
I've investigated my drooping mirror with the screen mirror strapped to it:
I tried PTFE tape and it drooped
I tried pieces of double sided adhesive tape in the ball socket, it drooped
I took the screen mirror off and the original mirror then drooped which it didn't before so things had got worse.
I cleaned the ball with isopropyl alchohol and the original mirror didn't droop, but the screen mirror did.
I used abrasive paper on the ball and the original mirror, the screen mirror still drooped.
I then used a temperature controlled heat gun set to 140C to heat up the socket edges, the screen mirror then stopped drooping. The ball is noticeably tighter in the socket.
i think the socket for the ball may have enlarged in heat and me moving the mirror about recently. Heating it allow sit to relax back to it's original, tighter, shape. maybe.
The vibration is still there, it's from road vibration and i can't get rid of it.
Post #959255 23rd Jul 2022 10:31am
blackrock
Aargh!
I've tried taping the mirror to the original mirror,
taped a lump of brass and a strip of steel to the back,
used double sided sticky tape to tape new mirror to old,
removed squishy pads on the back of the new mirror,
tried upside down,
tried tightening the bungees,
and it still wobbles....
I have noticed a bit of play on the mirror stalk mount and the fixing underneath the mirror stalk only has 2 screws holing it on for some reason, not 3. maybe it's that? Original mirror is still fine.
Do the screws holding the mirror fixing have nuts behind them, or do they run in tapped holes?
Post #959353 24th Jul 2022 10:41am
Dinnu
Older Defenders screw into rivnuts. Not entirely sure if they are still rivnuts on newer ones, or were changed to spire clips (for self tappings). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #959371 24th Jul 2022 1:28pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I had one of those clip on rear view mirror camera screen thingies. I took it off, the extra weight caused vibration and droop.
There is this which is a direct swap.
https://defenderupgrades.co.uk/product/lan...nitor-kit/
I've not tried it yet.
I'm also looking at a wireless camera that works with a phone app. Most of the time reversing with the mirrors is OK. I would only need a camera in a really tight space.
Post #959471 25th Jul 2022 2:30pm
Dinnu
Used the Defender over the weekend and today, and noticed that there is vibration in the rear view mirror. I had not noticed that before... think I always use the side mirrors during normal driving Whistle 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #959504 25th Jul 2022 5:38pm
Dinnu
So similar
https://www.aliexpress.com/item/1005003578...2345%21sea
What I do not like about it is that it is designed for left hand drive vehicles. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #959505 25th Jul 2022 5:45pm
