Home > Off Topic > Stihl Battery Garden Tools |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1579 |
We use Buxtons and fr jones. You should get 10% off
26th May 2021 3:37pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4206 |
RobKeay, when you say they don’t like hawthorn that’s a problem as I have a fair bit. I was literally about to place my order and now I’m worried it’s a lot of money for something that might not work on my hedges. How much of a problem is it? My cheap as chips Titan 2 stroke copes ok.
I’d also talked myself into getting the HSA 56 regular hedge trimmer at the same time. 2007 110 TDCi Station Wagon XS |
26th May 2021 4:11pm |
We use a 56 for sides only and the tops with the 131. Our 56 has broken three times. But since now only cutting sides and using resin remover it’s been great. The 85 with the longer reach has saved two hours on some of the bigger trimming jobs.
The 131 is a direct replacement to the old petrol combo units. The advantage is you use one engine for all tasks. But it’s very expensive and uses a 200 battery in an hour. So we have two batteries for that one unit. But it runs the strimmer and hedge cutter. But all that will be north of a grand. |
26th May 2021 5:13pm |
I think it worked out about £1200 for the battery combi with long reach hedge cutter and brushcuttter. That's with 2 200 batts and the slow charger. Too rich for my blood. I only do the hedges 2 or 3 times a year. 2007 110 TDCi Station Wagon XS
26th May 2021 5:39pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3268 |
+1 for Kramp resin remover. Great stuff. Are you using battery chainsaws? I've demo'd a bunch of them over the last couple of years but wasn't convinced until I tried the Echo 2500T. I wouldn't be without it now, fantastic pruning saw. WARNING. This post may contain sarcasm. |
26th May 2021 7:25pm |
You’ll get on fine. I am looking at it from my point of view. If it works with us for more than a year it’s mega. Tree surgeons second to scaffolders ruin everything.
Battery powered gear the pros beat the cons. |
26th May 2021 9:52pm |
Zed
We are only using battery strimmers and hedge cutters. But I saw the makita top handle and am tempted to try that. |
26th May 2021 9:54pm |
Mitchnotrich Member Since: 27 Apr 2019 Location: Worcestershire Posts: 43 |
Milwaukee do a range of battery operated strimmers and hedge cutters. That way I had an excuse to buy myself an impact wrench as well..... 90 - Gone but not forgotten
200 tdi - sold for a song 3 Discoveries - 1/2/3 - cost me a fortune but loved 'em all 2.4 Puma 90 - Current obsession |
27th May 2021 5:55am |
Funny you should say that. The Milwaukee combi tool with line trimmer with battery and charger comes with a free hedge trimmer as part of there current Redemption offer. So I stopped ummimg and arghing over Stihl and just ordered that plus an extra battery. Saved myself nearly £200. I already have some M12 products so that was all the excuse I needed to get into M18. I’m sure it won’t be as good as Stihl, but I’ll report back. This whole thread was a bit of a waste of time 2007 110 TDCi Station Wagon XS
27th May 2021 6:12am |
Stihl have been late to the battery world. We are considering different makes.
27th May 2021 3:00pm |
I can see batteries make sense for home users like me, but the cost of the really big batteries and the run time limitations must make them hard to justify for pro use. 2007 110 TDCi Station Wagon XS
27th May 2021 4:38pm |
We spend thousands on two stroke every year. We have cut our fuel use by 1/4. Using the new style kit has saved hours on several jobs. No spark plugs and other items and servicing. Less vibration and no fumes and the lads like using it.
Yes it was expensive buying several chargers and batteries. |
27th May 2021 4:46pm |
What sort of lifer do expect from the batteries? 2007 110 TDCi Station Wagon XS
27th May 2021 5:45pm |
Daily use we have 18 month old ones. Run to flat then charged back to full. No battery issues so far. They also protect themselves from cold and overheating etc. I believe they are Panasonic. My maths worked out anything over a year we are up over fuel use alone.
The new kma-131r is a beast of a machine. The unit itself if you already have batteries is cheaper than the petrol model. |
27th May 2021 6:30pm |
