Home > My Defender > What Did You Do In Your Defender Today |
Thanks ~ off to look at his products. |
22nd May 2021 7:07am |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 906 |
Managed to get the bottom of my inoperative difflock. Caused all sorts of strife during a day's laning in Dartmoor a couple of weeks ago. I couldn't even persuade it in with a screwdriver from underneath. Most odd.
I suspected it was a bit seized from lack of use by the previous owner so set about taking off the carpets and gaiter to try and lube it up. Turns out the problem was the rubber gearstick gaiter. The aperture for the HL lever was not wide enough to allow full sideways movement to engage the difflock. I changed it for the one from my TD5 which is stripped while it awaits decent weather for a paint job. Side by side: Click image to enlarge And the duffer from underneath: Click image to enlarge Difflock works perfectly now |
22nd May 2021 1:26pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10733 |
The one on the right is what i have on Millie, not sure what year the " duffer " one is from, good you got it sorted 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
24th May 2021 9:17pm |
Many thanks nitram 17 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
24th May 2021 9:22pm |
Well, i was well in the boundary until the groundsman moved it to where it is now as he was cutting the grass 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
24th May 2021 9:26pm |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
Today I pulled into the garage, unloaded my stuff, had some fun with the dog and then hopped right in, and very slowly backed into the park with the door still open. DOH
Luckily it appears to only have damaged the bottom corner of the door. Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Roaming around 🇳🇴🇨🇭 |
26th May 2021 11:39am |
double Roaming around 🇳🇴🇨🇭
26th May 2021 11:40am |
Ouch Darren
26th May 2021 11:43am |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Finally got to fit the Bluesea Terminals.
Great improvement! Click image to enlarge Click image to enlarge Rgds. Chris |
29th May 2021 8:52pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Hi do you know the biggest fuse you can use or total rating for that blue sea unit?It looks a neat option if your not planning on wiring the star ship enterprise.
30th May 2021 9:02am |
30th May 2021 9:03am |
It's this one:-
https://www.mudstuff.co.uk/collections/fus...1460764757 Rgds. Chris |
30th May 2021 10:36am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10379 |
Went and did the dishes.
Click image to enlarge |
30th May 2021 4:39pm |
