![]() | Home > Td5 > Oil pressure gauge |
I believe above the oilfilter and then to the rear off the engine. I don't know what you will need. I looked at it years ago and then found that my sensor didn't work. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
HenrikSw Member Since: 29 Jan 2021 Location: Skåne Posts: 29 ![]() ![]() |
Thanks!
![]() Some one got a photo or an example on a T-connection used for temp or pressure gauges. Plus any good or bad experience |
A.Rubio Member Since: 04 Mar 2017 Location: Rocafort -Valencia Posts: 32 ![]() ![]() |
Hello i put this adapter
https://www.amazon.es/gp/product/B0046Y80D...&psc=1 |
Thanks, seems like a smooth connector.
Where exactly did you put it? Any challenges with installing it? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6658 ![]() ![]() ![]() |
Be careful as there are two types of Td5 oil pressure switch.
M10x1.0 straight thread 1/8 NPT 27tpi tapered ![]() ![]() |
Hi Martin,
is there anyway to determine which one to use? I have an early Td5 -99 Defender Also looking to buy a kit so if anybody know a good supplier please share. |
No Youtube video that show oil pressure installation on a Td5?
Any helpful photos are much appreciated. As mentioned before also suggestions on places to buy the correct parts are appreciated. ![]() |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge https://www.defender2.net/gallery/albums/u...b_0007.jpg |
Hi Rubio!
![]() ![]() ![]() ![]() Thanks for pictures and links, much appreciated! |
