Home > Maintenance & Modifications > Aluminium or steel rivnuts
Fellrunner
 2015 Defender 110 Puma 2.2 SW Corris Grey
OK, I’m probably over analysing this one, but thoughts/advice much appreciated ...
I’m about to fit interior window guards to the rear windows. Rivnuts and bolts seem to be the best and most flexible option for the long term. I was planning on using stainless steel rivnuts, coated with the anti-corrosion paste before installing to help prevent galvanic corrosion, and then use stainless bolts. But, then I read some advice re using aluminium rivnuts to help avoid the corrosion in the first place. But wouldn’t I then just have the same issue between the bolt and the rivnut, as opposed to between the rivnut and the bodywork. So it really makes no difference?
Thanks
Post #904969 25th May 2021 6:26pm
Dinnu
Depends what becomes the anode.
Keep in mind that pure aluminum is the most corrosion resistant by itself. But is practically useless for a mechanical part because it is so soft. Once alloyed, then it is more prone to corrosion. If you want the least galvanic incompatibility but retain strength, then monel is the best choice. But not readily available. Using an isolating paste, such as Duralac is the 2nd best option. I have used a lot of stainless (generally grade A2) in my 90 and been using them for 25 odd years without issues. But I isolate them (and most of the time check isolation with an ohm meter to be sure). But then again where my 90s are is less wet although still salty environment. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #904975 25th May 2021 7:03pm
Fellrunner
Dinnu - thanks for the answer. Makes me realise I should have paid much more attention to chemistry at school!
So, and bear with me, if I use duralec, it sounds like using steel is the best idea due to strength (both rivnuts and bolts)?
Post #904977 25th May 2021 7:26pm
Dinnu
With steel bolts there should be less potential (literally) and hence less galvanic corrosion. Try to get ones with decent galvanizing. There are hot dipped galvanized bolts, which are better than plates bolts.
Personally I do not like rivnuts, they can also spin (unless they are haxagonal) and hard to isolate completely. If can reach both sides, bolt nuts and washers is a better solution. I isolate washers by sticking duct tape to the side which will go in contact with the panel and then trim the extra tape with a scissors before installing.
Note that the aluminium on later Defenders seem to corrode even when not in contact with dissimilar metal. Look at roofs. They tend to corrode from all edges. Or perhaps galvanic corrosion between different aluminium alloys (roof frame and sheet metal). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #905011 25th May 2021 8:59pm
Re: Aluminium or steel rivnuts
Thanks
It's less of an issue for stuff fitted inside as they won't be constantly exposed to water (even allowing for typical Defender leaks). Generally though, I'd suggest choosing the rivnut to match the material that it is being set into and then isolate the bolt with a suitable paste or grease if that's significantly different. It's much easier that way around. So, aluminium rivnuts in aluminium and stainless bolts coated in Duralac. Darren
Post #905025 25th May 2021 9:51pm
Fellrunner
Many thanks 👍
Post #905052 26th May 2021 9:05am
