Home > Maintenance & Modifications > Rx 8 seat wiring |
big ives Member Since: 24 Dec 2013 Location: Northern Ireland Posts: 125 |
The wire colors are:
Seat Motion Grey - +12v Purple - Ground Lumbar Yellow w/red stripe - +12v White w/yellow stripe Ground Seat Heater Blue - +12v hope this helps 2016 Discovery 4 1989 90 CSW V8 (fully rebuilt and running like a dream) 1996 defender tray back fully rebuilt/loaded for challenge events |
8th May 2021 2:42pm |
balmybaldwin Member Since: 17 Apr 2021 Location: Surrey Posts: 192 |
I'm no help, but I'm interested....
Will you need to unbolt the seats to access the seatboxes in future or are the bases removable? I used to have an rx8, just don't remember the seat bases coming out. I do remember them as by far the best seats and cosiest heat warmers of any car I've owned tho |
24th May 2021 10:33pm |
AT1963 Member Since: 08 Jul 2020 Location: Leicestershire Posts: 148 |
Great seats (i had them in mine) but couldn't sort out wiring so took them out. Actually MOT man said it would be automatic fail if he was unable to move the seats
Base does not separate so that needs considering. |
25th May 2021 3:50pm |
newton-tony Member Since: 18 Sep 2016 Location: Wiltshire Posts: 122 |
I have all wired up and the RX8 seats are excellent. At least 3 options for under seat access:
1. My seats adjust back far enough so I can still access battery etc (fiddly, but works for most things) 2. There are gold coloured nuts holding the RX8 seat bases in place. Easy to remove these and/or replace with wing nuts so base can be quickly removed, when needed 3. Others have fashioned brackets that allow the seats to simply tip back, when front fastenings are removed. If interested, just search via Google or YouTube |
25th May 2021 6:43pm |
