Home > Maintenance & Modifications > Rx 8 seat wiring
Biffa90
United Kingdom 1994 Defender 90 300 Tdi HT Epsom Green
Rx 8 seat wiring
Hi All,
Apologises me again, I've removed the Airbags and kept the trim thanks to a fantastic video I found on YouTube.
Next question is about wiring, my understanding is.
Yellow srs - cut off
Grey is seat motion?
Purple is ground?
Heater blue?
Can anyone help as I can't figure out the rest....
Post #902031 8th May 2021 2:37pm
big ives
The wire colors are:
Seat Motion
Grey - +12v
Purple - Ground
Lumbar
Yellow w/red stripe - +12v
White w/yellow stripe Ground
Seat Heater
Blue - +12v
hope this helps 2016 Discovery 4
1989 90 CSW V8 (fully rebuilt and running like a dream)
1996 defender tray back fully rebuilt/loaded for challenge events
Post #902033 8th May 2021 2:42pm
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
I'm no help, but I'm interested....
Will you need to unbolt the seats to access the seatboxes in future or are the bases removable? I used to have an rx8, just don't remember the seat bases coming out. I do remember them as by far the best seats and cosiest heat warmers of any car I've owned tho
Post #904847 24th May 2021 10:33pm
AT1963
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Great seats (i had them in mine) but couldn't sort out wiring so took them out. Actually MOT man said it would be automatic fail if he was unable to move the seats Shocked
Base does not separate so that needs considering.
Post #904949 25th May 2021 3:50pm
newton-tony
United Kingdom 2014 Defender 110 Puma 2.2 USW Firenze Red
I have all wired up and the RX8 seats are excellent. At least 3 options for under seat access:
1. My seats adjust back far enough so I can still access battery etc (fiddly, but works for most things)
2. There are gold coloured nuts holding the RX8 seat bases in place. Easy to remove these and/or replace with wing nuts so base can be quickly removed, when needed
3. Others have fashioned brackets that allow the seats to simply tip back, when front fastenings are removed. If interested, just search via Google or YouTube
Post #904981 25th May 2021 6:43pm
