Home > 130 > GVW question
Page 2 of 3 <123>
22900013A wrote:
My old works 130 (61 plate, single cab with box body) was a cut and shut job with an extension piece in the middle ...
Are you absolutely sure it was an extension piece, not the double-plated reinforced area where the chassis is most stretched?
A 61 plate vehicle would not have a stretched chassis, but I have met people who have mistaken the beefed-up section for an added section.
A little quick research since my post above has confirmed that the 127s were built on stretched 110 chassis, but the 130 was built on a bespoke chassis. The change happened in 1990 when the 200Tdi was introduced, so a 61 plate 130 would not have been stretched, at least not from the factory.
Post #904844 24th May 2021 10:04pm
22900013A
It had a big plate around the middle...in either case if they were all built on the same chassis it only adds to the confusion. If they were still 3500kg in 2010, why would the figure be reduced by the time my brochure was printed (2011 I assume from when I got my 110). So they were by then producing essentially the same vehicle but with two different GVWs. I still can't understand why? I could totally understand different payloads and unladen weights, but why the gross?
As an aside I'm pretty sure early 127s only had a GVW of about 2700KG, they were uprated about the time they got deeper wheels. I'm not sure what other changes occurred.
I have to wonder if this change to 3380kg was for the same reason they dropped the factory optional 3500kg version of the 110, which was something to do with c&u regs? Maybe the 130 was affected earlier? 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #904854 24th May 2021 11:38pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
This picqued my interest... I've had a trawl through the DVLA data and 3380kg starts appearing with 2011MY (BA) vehicles, and only on the 130 4 door pickups (SALLDKV) and 130 4 door chassis cabs (SALLDKX). There are few on 3500kg but the vast majority are 3380kg.
I wondered if it could have been removal of the helper springs to give the extra passengers a nicer ride that caused the drop in GVW, but this 2012 model has them, so maybe not Laughing . Probably more to do with regulations. The VIN plate will be the key confirmation.
As for the HD 110s after 2011 MY, they were all ROW or Military, except for (at least) 4 that are registered in the UK in 2014 and are 2013 MY. LR Workshop
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #904934 25th May 2021 2:40pm
kenzle8a
Smyles_ wrote:
The GVW of my 110 DCPU was 3050 kg, whilst the GVW of my 130 is 3500 kg
Your DCPU was a 2005 TD5? How odd, my 2003 TD5 DCPU is plated for 3500 GVW.
Post #904952 25th May 2021 4:03pm
22900013A
The 110 3500kg was always an option though, so all models aside from the station wagon could be 3050 or 3500.
I'm still none the wiser as to why the 130 four door got down rated though.. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #905498 28th May 2021 3:27pm
I think this could be one of those Landrover mysteries which we never solve (along with the purpose of the two little panels in the front bulkhead of the rear body, and a few other similar mysteries).
Post #905509 28th May 2021 4:10pm
Is the chassis of a 130 DCPU different to that of single cab to accommodate the second row footwell? If so, perhaps that precludes the uprating to 3500kg in some way? Darren
Post #905560 28th May 2021 10:13pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
My May 2010 130 DCPU is 3500kg
Max front axle weight 1580kg
Max rear axle weight 2200kg 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #905589 29th May 2021 8:36am
Bluest
Is there some taxation or legal reason why keeping under 3050kg is important? Was there some reason why it would be advantageous to register it with a 3050kg gross even if mechanically there is no difference.
Possibly coincidence, but I can see that same figure is important as an unladen weight for motor homes in relation to speed limits, but can’t see any relevance to GVW. 2007 110 TDCi Station Wagon XS
Post #905600 29th May 2021 9:30am
Matt110
Traditionally on other commercial vehicles with similar configurations... Double cab in vans, transits for instance, they're plated differently because it's assumed you cannot load a passenger compartment area the same way you would a load bed.
Thus... You put 3 abreast in the rear of a 130 dcpu (good luck to you, I guess you could ask them to breathe in and slam the door very hard), that's "only" 3 x75kg (average assumed passenger weight) and 225Kg.
To get the vehicle to GVM at 3500Kg you'd then need to exceed the rear axle plated weight. So the GVM is dropped to the maximum you could achieve.
With a single cab, you are technically able to move that load further forward and make more of the front plate, thus you can reach the 3500Kg GVM without exceeding either axle load.
I've not worked it out for the defender case but that's how it works on vans. What happens if you do that with Defender numbers?
I guess it's a mute point if people have also got 130 DCPUs with 3500Kg GVMs.
Post #905626 29th May 2021 4:21pm
22900013A
Did a little more digging on this via my handbook. ROW 130s were all 3500kg gvw, only UK/Europe were reduced and they also had lower train weights which makes sense.
So sounds to me like it was some kind of legal restriction, not an engineering issue, and may be the same causal factor behind the demise of the 3500kg gvw 110s in around 2012, that was something to do with how the weights were measured? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #906516 4th Jun 2021 9:52pm
RFT
Just a thought, was the change associated with the addition of ABS and TC to the 130 range, my 2010 130 does not have ABS etc. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #906522 5th Jun 2021 5:26am
22900013A wrote:
... So sounds to me like it was some kind of legal restriction, not an engineering issue, and may be the same causal factor behind the demise of the 3500kg gvw 110s in around 2012, that was something to do with how the weights were measured?
I'm not actually aware of any legal reason why this should have been the case (which doesn't mean it isn't though).
I think that the 130 gained ABS/TC in about 2013, so this is suddenly a very plausible theory. Are there any 3500kg 110s with ABS and TC that we know of?
Post #906534 5th Jun 2021 7:52am
22900013A
I have ABS/TC on my 110 and certainly the 3500KG option was available at the time, as I nearly specced it.
My handbook dates to 2011 when I got my 110 so the change to lower GVW had already taken place then. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #906541 5th Jun 2021 9:46am
backpacksandroofracks
United Kingdom 2006 Defender 130 Td5 HCPU Alveston Red
My 2006 TD5 Double Cab 130 has a GVW of 3500kg, just to add to the pot!
Post #910791 5th Jul 2021 8:58am
Page 2 of 3 <123>
