Home > Technical > Electronic CDL |
Yes, the Puma still uses the LT230 transfer box so there's no particular reason why it shouldn't fit.
Yes, it's something else that could go wrong. I'm not sure that helps Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
24th May 2021 1:25pm |
Smyles_ Member Since: 25 Aug 2018 Location: Copenhagen Posts: 518 |
I'll be having air controlled lo/hi and diff lock controls on my 130s box, but having seen the size of the pneumatic actuators they use I'd be concerned if that vacuum actuator would be up to the task - although I have absolutely no experience with them, so feel free to ignore everything I've just said Stuart
Cummins 130 Build Thread 58 130 Double Cab HCPU - Cairns Blue 04 110 Double Cab - Black (gone) 07 Audi RS4 Avant - Silver |
24th May 2021 1:50pm |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 |
As stated above, unless you use hi/lo/lock regularly and it moves nice and smoothly, I'd guess that would be underpowered.
Had to use the difflock for the first time recently; it was an absolute pig to get in and even worse to get out. 2011 CSW XS 90 |
24th May 2021 6:00pm |
