Home > Technical > Electronic CDL
Silver110
England 2008 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Electronic CDL
Hi all,
Seen this advertised on ebay.
Just in the process of installing Ashcroft lockers and thought this might be a “cool” addition to have and also fill up a blank switch spot.
Just thinking it may just be another thing to go wrong.
Tbf not even sure it fits the Puma transfer box? I have a 2008 Puma does that still have the LT230 TRans box.
What’s your thoughts.
Post #904696 24th May 2021 12:44pm
Yes, the Puma still uses the LT230 transfer box so there's no particular reason why it shouldn't fit.
Yes, it's something else that could go wrong.
I'm not sure that helps Confused Darren
Post #904704 24th May 2021 1:25pm
Smyles_
Denmark
I'll be having air controlled lo/hi and diff lock controls on my 130s box, but having seen the size of the pneumatic actuators they use I'd be concerned if that vacuum actuator would be up to the task - although I have absolutely no experience with them, so feel free to ignore everything I've just said Very Happy Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #904706 24th May 2021 1:50pm
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
As stated above, unless you use hi/lo/lock regularly and it moves nice and smoothly, I'd guess that would be underpowered.
Had to use the difflock for the first time recently; it was an absolute pig to get in and even worse to get out. 2011 CSW XS 90
Post #904782 24th May 2021 6:00pm
