Home > Puma (Tdci) > Hot and....warm!
bear100
Hot and....warm!
This is a bit strange!
On a long drive home today I noticed the cab was getting very warm, so I turned the heater control to cold but it didn’t get cold! The passenger side was still blowing hot and the drivers side was warm, a big difference in temperature between the both sides, both should have been freezing because I never turn the aircon off which was re-gassed last year.
Any ideas? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #904487 22nd May 2021 10:32pm
The nearside outlet on a Puma always blows hotter than the offside due to the quirky (i.e., poor) design of the heater box, there is really very little you can do about it. The fact that it was blowing warm with the heat control set to cold suggests that the heater valve is kaput, or the cable connecting the heater valve to the knob is out of adjustment or has detached itself. It does take a long time to cool down if you have had it on hot, though.
The heater controls are somewhat fragile, and although the Puma heater is years more advanced than any earlier Defender or Series heater, it was still about 30 years behind the cutting edge when introduced. It does at least give out heat, unlike most earlier ones.
Post #904491 22nd May 2021 10:56pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
I have this with mine, found out if I want cold and somebody has turned the dial to hot, I need to open the bonnet to fully close the heater valve or the hot water sneaks in. Now I have not checked if it can be adjusted but as I like it cold that’s simple for me. Think some have mentioned zip tying it to the closed position in the past. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #904523 23rd May 2021 9:26am
Siwynne
I had this and added a spring to return the valve to closed. Strong enough to return but not so strong to overwhelm the notches on the dial
Post #904544 23rd May 2021 1:17pm
Siwynne
Also check coolant level mine blew cold on drivers side when it was lower.
Post #904545 23rd May 2021 1:19pm
Ianh
That’s a very practical solution to getting the valve to close by that extra 1/4 , which seems to make all the difference. Do you have measurements for the spring and remember where you got it ?
I was thinking of a little fabricated bracket on the heater motor housing to hold the spring, although your existing solution looks reasonably robust.
Post #904555 23rd May 2021 3:14pm
Siwynne
Sorry the spring was in a paper sweet bag of springs I bought from a proper old fashioned diy shop in Keswick when the return spring on the carb disappeared when I was there in my old Vw beetle.
I experimented a bit with length to get the amount of force just right.
Post #904567 23rd May 2021 6:17pm
bear100
Some great tips, thanks
So the spring fits to where the cable connection is and adds extra tension to keep the valve closed?
Yeah first thing I checked was the coolant level, a little while ago I flushed the system through and filled up with fresh, all full and bled! 2023 Defender L663 V8
Post #904576 23rd May 2021 6:56pm
Siwynne
Yes the spring just gives enough pull to return the valve to closed. Looped over the pin that connects the control cable.
Post #904603 23rd May 2021 9:45pm
familymad
Love threads like this. Designed by LR refined and made to work by owner ... Rolling with laughter 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #904631 24th May 2021 8:47am
camelman
I get this issue occasionally on the puma. Appears to sort itself out if I put the air conditioning on briefly, wait for the cold air to start coming through and then knock the aircon back off. Haven't spent the time yet to work out why Whistle
Post #904641 24th May 2021 9:58am
Matt110
Can also be the heater duct not sealing to the blower unit. I did a thread on how to fix it a while back.
Post #904661 24th May 2021 11:10am
If the heater matrix contains hot water, it takes a long time for the airflow to cool it down. Most vehicles now divert the air away from the heater matrix on cold to avoid this, but not LR on the Defender, so you have to wait for it to cool. Using the a/c briefly probably just accelerates the process.
Post #904665 24th May 2021 11:20am
dorsetsmith
^ post 07 only ^
Post #904666 24th May 2021 11:33am
Yes, sorry I should have made it clear that I was talking specifically about the TDCi i.e., post '07. Comment are also true though for the Series 1 and 2 "fug stirrers", but I have no experience of anything in between.
I don't think heaters and climate control systems have ever really been Landrover's strong point. Hopefully they'be got it right at last on the prestige vehicles that are now their exclusive interest!
Post #904670 24th May 2021 12:13pm
