Home > Puma (Tdci) > Brake Caliper question
mangobay
United Kingdom 2008 Defender 90 Puma 2.4 CSW Epsom Green
Hi all
Im just looking for a quick piece of advice please if anyone can help?
Im looking at calipers for the front brakes on my 2008 2.4 TDCi Puma, and trying to establish of the calipers from a 2.2 TDci are the same as those on the 2.4?
Reason for asking is that I want to change mine to a refurbed set but cannot afford to have the vehicle off the road while I send mine away for a refurb, so looking at the option of buying some second-hand 2.2 ones I have found and having those refurbed before king them for a (hopeful) straight swap.
thanks in advance
Post #904056 20th May 2021 10:54am
Bluest
I think you just need to make sure you choose the callipers to suit vented or unvented discs to match what you already have. Generally, 110 fronts are vented, 90s are not. 2007 110 TDCi Station Wagon XS
Post #904057 20th May 2021 11:02am
mangobay
thanks for the reply.
I was planning to move to Vented and buy some new Vented discs to go with the calipers. the 2.2 TDCi ones i have found are stated to be for vented discs from a 2.2 - so i was just hoping to check if the fitment/attachment was the same as on the 2.4.
thanks
Post #904062 20th May 2021 11:22am
hank
Caliper fitment is the same.
Vented have a metal spacer between the two caliper halves to accommodate the additional thickness associated with vented discs.
Unvented do not have this spacer...
Vented
Unvented
 > 110 XS Double Cab
Post #904063 20th May 2021 11:27am
hank
Actually, how urgently do you need a pair? Like you I have refurbished a pair of vented calipers to fit to mine as I cannot afford to have the vehicle off the road for the duration of caliper refurb
I will be fitting the refurbed calipers soon so will have a pair of OE 2.4 vented calipers spare. Local too in Newport, > 110 XS Double Cab
Post #904064 20th May 2021 11:29am
mangobay
Hi Hank
thanks for the really helpful info, and also for the suggestion - I can defo wait, not urgent, so if you re happy to move your old ones on to me in the not too distant future than that would be a perfect suggestion, thanks! will happily pop over and collect etc. thanks
Post #904067 20th May 2021 11:34am
Would it not make sense to refurb the 'spare' set first and just fit those as a one-off task rather than swap them and then swap them again? Particularly if changing from unvented to vented? Darren
Post #904085 20th May 2021 12:55pm
mangobay
Yes that's exactly what i have in mind! thanks
Post #904090 20th May 2021 1:24pm
Sorry, misread your first post. Thought you were planning to fit some second hand ones whilst you had your originals refurbed. Darren
Post #904097 20th May 2021 2:25pm
