Home > Maintenance & Modifications > 1999 defender 90 TD5 Sump plug botch |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 531 |
Discovery and and defender sumps are the same, just need gasket for sump to block and gasket for turbo drain. Its a messy but ok job. Jack up front of car to let axle drop and give you more clearance to work.
18th May 2021 9:20am |
cee-b Member Since: 25 Jan 2018 Location: South West Posts: 117 |
All Td5 sumps are the same.
As to availability of gaskets, a quick Google search will show that they are readily available from a multitude of sources. |
18th May 2021 9:24am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17448 |
Are you sure you need a new sump, rather than just a new sump plug?
18th May 2021 11:56am |
Or tap out to next sump plug size up if there is enough room. Re tapping kits available on ebay and other outlets. Done this a couple of times with a range of cars.
18th May 2021 12:36pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
I would try to drill and rethread and then fit a Femco drain plug, so you don’t keep working the thread.
19th May 2021 6:48am |
