Home > Maintenance & Modifications > Puma Brake Servo on TD5
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
I heard that if i use the Puma brake booster i can gain better braking.
New Puma Brake booster, Rakeway big brake kit, slightly used brake master
Currently i am suffering from worse brake system. With the td5 brake booster it was fine, i was able to stop, but not lock the tires. Now its pray and press harder to slowly brake.
We bled all the brakes three times, and there is no air, i have vacuum from the pump. and neither revvin the engine or at idle has any effect on the stopping power. Its rock hard and stops very soon.
if i am on a hill and try applyin the brakes, its a very slow brakin situation. there is no way to stop abruptly.
Let me know your thoughts. Can't leave well enough alone
Post #902134 9th May 2021 9:39am
geobloke
Hey Naf.
I think that the brake servo (certainly the non-ABS version) has the same part number from 200tdi all the way through to the end of the TDCi.
Unless you are talking about fitting the ABS (SJG100240) servo in place of the non-ABS (LR013488) servo!?! In which case I cannot help, but am interested if a worthwhile mod.
Post #902140 9th May 2021 10:37am
Naf
I have the abs version on my ride with the stock td5 master cyl.
We will test to see if there is an internal leak in the servo, and if need be we will swap the master to the newer version as it has a larger internal bore to push more fluid. Can't leave well enough alone
Post #902155 9th May 2021 1:08pm
bankz5152
There can be hairline cracks in the servo. Instagram @defender_ventures
Empire Tuning - Agent
Post #902167 9th May 2021 2:22pm
Naf
Its new, but its still a defender part.
I will try and do a vacuum test to see if thats the problem.
Have a lot on our plate, and holidays are fast approaching Can't leave well enough alone
Post #902188 9th May 2021 3:49pm
Naf
I think we found the problem. The non abs master has a smaller oring than the abs type.
Investigating at the moment. Can't leave well enough alone
Post #902285 10th May 2021 5:44am
Naf
Yes, the ABS master has a larger opening than the non-abs. Serious DUH moment.
So next hurdle is the non-abs has m10 female fittings while the ABS type uses M12 fittings. Problem partially solved, Dorman 788-522 is a m12 male bubble to m10 female inverted, you just drill out the inverted part in the female side and you may retain your original piping. You will also need to remove the five sided Allen key plug on the bottom of the new ABS master.
I hope to have this all altered and working by 7-10 workin days. I have the master comin from the UK and the adapters comin from Amazon USA.
Will keep you all posted. Can't leave well enough alone
Post #902646 12th May 2021 7:32am
Naf
Latest update,
Ordered a new aftermarket master, the bottom plug is just a stopper for the front plunger. No oil pressure comes from there.
We will be addin a Tee fittin to the front plug and see if it all works out nicely.
Another day of delays... Can't leave well enough alone
Post #903535 17th May 2021 12:18pm
jst
not sure i follow the last post.
but once you have vacuum if actuation of brakes compared to pedal press is poor (ie lots of slack) then adjust out the screw to reposition the master piston where it mates to the servo. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #903686 18th May 2021 8:05am
Naf
JST,
You are correct, but my platform is No-abs, that I am tryin to install an ABS combo onto for better brakes. My current non abs combo never came close to lockin the wheels in the sand. It was never a situation where I wasnt going to slow down fast enough. Just wanted more from my brakes as i am running the larger kit from Rakeway.
The Non abs has three ports, the two on the front are for the front two hubs, while the third that is closest to the servo is for the rear two hubs.
The abs master has only two ports, from what I can gather online its Pressure and Supply. As these two go into the ABS module and it is adjusted and sent to the needed hubs. There is no Front and rear like on newer vehicle models.
I have a Tee fittin from and extra rear axle buy. So I would be able to make one of the ports handle the two front hubs.
I will try and see which of the new ports gives more fluid, and at what pressures. As we want more pressure for the front vs the rear. Can't leave well enough alone
Post #903695 18th May 2021 9:12am
jst
i have added ABS servos to non ABS vehicles and used the existing MCs. one option is different servo to allow this if as you say the MC outputs are not conventional front and rear. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #903711 18th May 2021 11:34am
geobloke
Hi JST. Curious to know what the difference in braking the ABS servo made when replacing a non-abs servo. Interesting that the non-abs MC fits the abs servo, I have wondered... Thumbs Up
Post #903738 18th May 2021 1:57pm
jst
I fitted them to auto conversions we did where the std servo provided insufficient assistance for cadence braking under certain conditions. I
didn't fit them to improve braking force just to give better servo capacity Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #903840 19th May 2021 7:09am
geobloke
Fair enough curious is all Thumbs Up
Post #903852 19th May 2021 8:10am
Naf
I ordered a collared seal to fill the gaps and it worked on the test bench properly.
Waiting on a new master before we bleed and give it street trials.
My older master has started to rust, and I don't feel like allowing this cancer to stay there.
Its another week, but it is better in the long run.
Post #903893 19th May 2021 11:35am
