Home > Maintenance & Modifications > Puma Brake Servo on TD5
Page 2 of 2 <12
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
New master arrived today.
Got a trw and britpart. Have to admit the britpart looks like a better quality unit than a stamped thin metal.
Pix to follow tomorrow. Can't leave well enough alone
Post #905132 26th May 2021 3:40pm
Naf
Follow up to an old post, the special seal fit perfectly. There is a gap between the non abs master and the abs servo. Once fitted a collared seal the brake pedal pressure feel great and the stopping power is better than before Can't leave well enough alone
Post #922169 21st Sep 2021 7:53am
geobloke
Interesting Naf Thumbs Up What is this collar you refer to? is it a bespoke part or a LR part?
Post #922174 21st Sep 2021 8:15am
Naf
Its a custom seal.
But any seal shop can make it easily.
Measure the OD of the master and ID of the servo and you will be set. Can't leave well enough alone
Post #922189 21st Sep 2021 9:32am
geobloke
Excellent. I figured as much.
The important thing is that the physical connection of the ABS servo to the pedal is the same as non-ABS servo. The adapter seal is simple enough Thumbs Up
Out of curiosity what are the diameters of the ABS servo diaphragms? Would be interested in what the difference is in surface area to the non-ABS servo.
Post #922196 21st Sep 2021 10:14am
Mo Murphy
Do you have any pictures, Naks?
50 Shades of Pennine Grey
Post #922217 21st Sep 2021 1:11pm
Page 2 of 2 <12
