Home > Technical > Stuck in the car park- alarm and horn when turning ignition
Page 2 of 2 <12
Ianh
Guinness wrote:
That makes a very good point, I have a 2002 TD5 110 CSW with central locking. The previous problem was the rear wiper fuse went. Ill have a look at the wiring where you suggested, thanks!
I would check the rear door ( not side doors) first then if it’s been a wiper and potentially a central locking issue that’s caused those fuses to blow. After 19 years of opening and shutting it would be my go to place. Lots of info on rear door wiring and if needed rear door card removal on here. Just make sure if you do remove rear door card you have already got spare door clips. Have some trim removal tools and have identified where the clips are . Also some multi core wiring, crimp splices, heat shrink, crimpers etc ready to undertake any repairs.
Post #903372 16th May 2021 11:06am
Guinness
Thanks all, I'll be sure to have a look when i have a spare minute and spare patience!
Post #903394 16th May 2021 2:03pm
Page 2 of 2 <12
