Home > General & Technical (L663) > Rust on new defender
MrEleven
Has anyone else noticed any rust on the back at the right hand side ? I actually noticed this a few months ago so its been there probably after 6 months of owning it. Should i complain to the dealer or is it just something that happens. Still have a bunch of faults with my defender that haven’t been resolved since right from the start.
Post #902718 12th May 2021 5:42pm
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
Just dodgy washers get the dealership to replace
Post #902720 12th May 2021 5:45pm
Ianh
If you look to the right of those washers you can see much more rust, and not from the washers. So have a very good look all under and over your vehicle, take lots of pictures, make a list and get the dearer to resolve.
Post #902726 12th May 2021 6:23pm
Retroanaconda
Mines the same, dodgy batch of fixings I reckon. I was going to just swap them out for some new ones but decided to just leave it, I’ll get the dealer to look at it as and when it needs to go in for another reason.
Post #902731 12th May 2021 6:34pm
It's been mentioned before but buried in the main discussion thread...
Gareth wrote:
Just the rusting ad blue tank cover to worry about now 😂
I see that some Facebook owners are confusing it with the exhaust/muffler. JLR issued this for that:
SSM 75174 - Customer Complains of Rear Muffler Discoloured
In terms of JLR's response, they will hopefully be following what they have done previously for other models with similar issues:
Post #902737 12th May 2021 6:56pm
MrEleven
Also noticed today, some condensation in the rear lights.
Post #903067 14th May 2021 5:56pm
Is it supposed to be a sealed unit, or can you open it to clean/dry?
Post #903142 15th May 2021 5:19am
J77
Pop the plastic panel off and have a look, see if waters getting in somewhere. 24MY 90 D250 HSE, Tasman Blue
Post #903166 15th May 2021 8:13am
I know that Gerry said he wanted the new Defender to inherit the DNA of its predecessors, but reading this thread makes me fear that some of the defective genes have also been perpetuated.
Rust and water-filled lights on a Defender, who'd have thought it!
Post #903174 15th May 2021 10:20am
Don't forget, they've opened the 1st chapter in the new water ingress manual and chapter 2 ~ windscreen leaks is just off the press.
Post #903184 15th May 2021 11:56am
Digger2000
Yes mines going in for a warranty fix for windscreen parts and a water ingress problem both are unbeknown to me.
Post #903245 15th May 2021 3:57pm
MrEleven
Mines is in the now for the rust and water in lights plus a few electrical faults. Just been told that the rusting might not be covered under warranty and there just waiting on confirmation then they will let me know for sure. Anything i can do if its not covered under warranty? It looks horrendous and is clearly noticeable.
Post #907234 10th Jun 2021 1:32pm
Digger2000
Where is the rust? I find it hard to believe that any part that starts rusting in the 3 year warranty period is not covered. Get in touch with LR solutions and asked them if it’s covered. The dealerships will try anyitp
Get out of a fix/repair
Post #907245 10th Jun 2021 2:10pm
Retroanaconda
I asked the dealer to look at it when it was in for the recall - got the usual brush-off response along the lines of “that will always happen sir, it’s not covered by the warranty”.
Not worth the argument, I’ll just swap the bolts out for new ones when I get around to it.
Post #907252 10th Jun 2021 2:35pm
MrEleven
Its not a case of swapping bolts on mine, the metal panel has two large rust marks on mine. One where the bolts are and another further down, if you zoom in on the photo you can just start to see it. Unacceptable on a car less than a year old.
Post #907254 10th Jun 2021 2:38pm
