![]() | Home > Wheels & Tyres > Where can I get 16" steel wheels? |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3394 ![]() ![]() |
Where are you based iggy? I might have a set in the shed.
Iguana Member Since: 05 Jun 2016 Location: WSM Posts: 111 ![]() ![]() ![]() |
Sunny Somerset
![]() No rush, also happy to get a courier sorted ![]() ‐------------------------ Vehicles: - 1992 Ex-Mountain Rescue Ambulance 130/200tdi - 2005 Discovery 3 S - 2001 BMW 535i V8 |
You'd be far better off with a set of 6.5 inch wide Wolf wheels rather than standard 5.5 inch ones, as you've have a greater choice of tyres to fit. You're really stuck with 7.50's on the original wheels whereas Wolfs give you access to the wide range of tyres in 235/85. Darren
Well managed to get 5x 16" for £25 off the bay
Tyres off Friday, then sandblasting and powder coat ![]() ![]() Click image to enlarge Iggy/Ieuan ‐------------------------ Vehicles: - 1992 Ex-Mountain Rescue Ambulance 130/200tdi - 2005 Discovery 3 S - 2001 BMW 535i V8 |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2720 ![]() ![]() |
Check they’re not the old tubed type - almost all the standard 5.5” steel wheels out there are tubed as they only made them tubeless for the last five or ten years of production.
Unless of course you want to run tubes for some reason. |
The tubeless rim is on the left and has an additional ridge each side to keep the bead securely in place which the tubed rim does not have as the tube keeps the bead securely in place.
