Home > Wheels & Tyres > Where can I get 16" steel wheels? |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3376 |
Where are you based iggy? I might have a set in the shed.
24th Apr 2021 9:41am |
Iguana Member Since: 05 Jun 2016 Location: WSM Posts: 111 |
Sunny Somerset
No rush, also happy to get a courier sorted Iggy/Ieuan ‐------------------------ Vehicles: - 1992 Ex-Mountain Rescue Ambulance 130/200tdi - 2005 Discovery 3 S - 2001 BMW 535i V8 |
24th Apr 2021 10:25am |
You'd be far better off with a set of 6.5 inch wide Wolf wheels rather than standard 5.5 inch ones, as you've have a greater choice of tyres to fit. You're really stuck with 7.50's on the original wheels whereas Wolfs give you access to the wide range of tyres in 235/85. Darren
24th Apr 2021 11:28am |
Well managed to get 5x 16" for £25 off the bay
Tyres off Friday, then sandblasting and powder coat Click image to enlarge Iggy/Ieuan ‐------------------------ Vehicles: - 1992 Ex-Mountain Rescue Ambulance 130/200tdi - 2005 Discovery 3 S - 2001 BMW 535i V8 |
12th May 2021 6:31pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2658 |
Check they’re not the old tubed type - almost all the standard 5.5” steel wheels out there are tubed as they only made them tubeless for the last five or ten years of production.
Unless of course you want to run tubes for some reason. |
12th May 2021 6:44pm |
The tubeless rim is on the left and has an additional ridge each side to keep the bead securely in place which the tubed rim does not have as the tube keeps the bead securely in place.
Click image to enlarge |
12th May 2021 7:05pm |
