Home > Puma (Tdci) > speed limit
lvcity
speed limit
hi guys, i have a defender110, it's speed limit is about 138km/h, is there anyway i can break this limit and make it go faster? thanks
Post #90132 20th Sep 2011 10:31am
Grockle
the speed limiter is set whilst doing the PDI, you could invalidate your warranty if you get it removed. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #90136 20th Sep 2011 10:46am
lvcity
thanks! you mean remove my warranty? how can i do it?
Post #90138 20th Sep 2011 10:55am
ZeDefender
A "friend of mine" has a speed unlimiter box that sits between the tacho and the "brains" and can be disconnected almost invisibly.
The "brains" are told the vehicle is within speed but the tacho reads the higher speed correctly. Nobody is any the wiser. It really is an awesome bit of kit... but also an awesome price: almost 700 Euros (from www.matzker.de)
However, "my friend" says it's worth every cent, even without other tuning Smile
Cheers,
Matt
Post #90139 20th Sep 2011 10:55am
lvcity
ZeDefender wrote:
A "friend of mine" has a speed unlimiter that sits between the tacho and the "brains" and can be disconnected almost invisibly.
The "brains" are told the vehicle is within speed but the tacho reads correctly. Nobody is any the wiser. It really is an awesome bit of kit... but also an awesome price: almost 700 Euros (from www.matzker.de)
Cheers,
Matt
thanks, i'l check that out!
Post #90140 20th Sep 2011 10:57am
Naks
Re: speed limit
Why would you want to go faster than this in a Defender? If you want to go fast, get a sports car Rolling Eyes --
Post #90146 20th Sep 2011 11:39am
dgardel
Italy
Re: speed limit
absolutely NOT!!!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #90166 20th Sep 2011 1:31pm
22900013A
If you invalidate your warranty you would have no comeback with the dealer or Landrover in the event of any malfunction of the vehicle, they will just say you removed the speed limiter so you no longer have any warranty. It is also probably not a very good idea to exceed the limit set anyway, as the vehicle was hardly built for high speed performance. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #90185 20th Sep 2011 3:33pm
pom
I dont think they could argue that because you went fast your warranty no longer counts.
Same as if you modify the car with new tyres, rack, spots, bumpers, ladder etc etc
There would have to be a provable direct link between the speed and the failure.
Pom
Post #90186 20th Sep 2011 3:36pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Something that I was pondering over in one of my frequent moments of boredom...
The rev limiter is sat at about 4500rpm, in top gear at 60mph it's doing 2000rpm, so...
60mph - 2000rpm
90mph - 3000rpm
120mph - 4000rpm
135mph - 4500rpm
Would the gearbox/diffs/whatever actually be able to handle that sort of speed?
I know I wouldn't want to attempt that sort of speed in a Defender anyway!
Post #90205 20th Sep 2011 5:48pm
BigMike
no. aerodynamics being the main issue. drive drain wouldnt take it either.
Post #90208 20th Sep 2011 6:00pm
Lorryman100
Without a remap, which resets the speed limit to whatever the tuner deems appropriate the only other option is to change the speed setting in the instrument cluster at PDI. The only option which removes the speed limiter is the Saudi Arabia overspeed function which is set at PDI and you shouldn't be able to change that. There is an option to set the limiter at either 82mph or 87mph with certain diagnostic tools. My limiter was removed with the remap though I rarely go faster than 80mph as I'm conscious of the strain on the drivetrain and the consequences of a blowout at high speed.
Post #90223 20th Sep 2011 7:12pm
ZeDefender
As an alternative, I can assure you "my friend" has a box from Matzker which takes the signal from the tacho and tells the system it isn't going faster than e.g. 130 kph. The tacho reads the real speed normally but the system is told something else. No remap, no trace in diagnostics. "My friend's" defender (without tuning) goes smoothly up to 150+ kph, most importantly without that "constipated" feeling you usually get at the limited speed. The box can be removed, e.g. for servicing, and the wiring (5 discrete wires and a small connector) can be tucked up behind the instrument cluster. Believe me, it's brilliant, especially on German motorways where suddenly finding your speed "stop" can be a problem.
p.s. I (er... I mean "my friend") also rarely go much above 145 kph but (he) hates being "constipated"...
Post #90240 20th Sep 2011 8:54pm
Sockpuppet
Why would you want to do 90mph plus in a defender?
25 mpg is bad enough are you trying to hit single digits?
Post #90243 20th Sep 2011 9:14pm
ZeDefender
Only in emergencies Smile
Actually, the consumption cruising at 145/150 isn't that bad - I drove to Italy and got over 20 mpg...
Post #90245 20th Sep 2011 9:24pm
