Home > Maintenance & Modifications > LED Tail & Indicator Lights
Page 2 of 2 <12
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
mse wrote:
Where did you get the LED units that are a direct replacement? im not sure if i like them, but am tempted. I assume it needs a new relay
took me a while to get used to the look, but know i think they look and are much more effective. i used an electronic relay which saved alot of time not fiddling wiring in resisitors.
I will add though that Land Rover could get the LED indicators but didnt for a few reasons, one like everything on the SVX is compromise 2 is servicability apparently (so you can easily go an get the bits)
according to microcat the svx indicators are led?
Post #9009 25th Mar 2009 9:18am
RickA
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
LED Relay
Nicks,
Could you tell us where you got the electronic flasher relay ( and a part number if it has one !) - I have the bulbs but can't find a relay that is a direct plug-in replacement for the standard unit.
If you just fit the LED's the relay acts like it has a bulb blown and clicks on-and-off very rapidly.
Look forward to hearing from you.
Cheers, Rick.
Post #9014 25th Mar 2009 10:02am
nicks
this is where i get the relays from -
http://www.mobilecentre.co.uk/landrover-de...p-282.html
these are the best type as they are plug n play and you can use normal lamps as well as led / mix
Post #9016 25th Mar 2009 11:13am
mlightfoot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Beetroot - Can you tell me where you got your LEDs and the plinths?
Post #9035 25th Mar 2009 9:21pm
beetroot
pm sent
Post #9049 26th Mar 2009 9:45am
Martin
Site Admin
Can you share with all of us please?
Post #9050 26th Mar 2009 11:48am
beetroot
Right i have just checked with them that they actually sell them seperately, as I had them fitted when they did the roll cage.
The lights came from protection and performance, www.ppcages.com, the rear kit costs about �500 + VAT, they are genuine peri lights like land rover use and i think look tons better than cheap copy ones, they come with genuine land rover plugs on so you can just swap them straight over, adaptor plinths so you do not have to re-drill the back body with std round fog light plinths, you also get the correct relay which is a direct swap and led bulbs that fit in the standard front indicator, clear or amber, so you dont have to swap the front lights. I have had this kit on for 9 months now and no problems.
I have also added a clear side repeater.
Post #9054 26th Mar 2009 2:10pm
nicks
its the reverse led unit that is the expensive one - �140.00 + vat list price, coloured lightrs are �40 each and clear are �50 each plus plinths.
Post #9055 26th Mar 2009 2:32pm
110SEB
Shocked It all seems rather expensive to me.
Post #9056 26th Mar 2009 2:47pm
mlightfoot
Seems frighteningly expensive to me especially considering the cost of the roverantics.co.uk LED set.
Post #9063 26th Mar 2009 4:40pm
beetroot
yeah i did consider not having the led reversing light, i dont think it would stand out too much if you left the standard one on, but for me I thought the led was brighter for reversing in the dark.
At the time i bought mine they were the only ones available, there is a choice now of cheaper versions, I still think these look the best of the ones i have seen though, and bieng an OEM part on a newish vehicle makes sense too.
Post #9065 26th Mar 2009 4:56pm
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
cool they look pretty neat. The link is broken, got another link? Cheers. '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #12803 9th Jul 2009 4:21pm
MUF
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Has anybody bought from this seller on FLEA BAY?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...tsupported
Post #13820 4th Aug 2009 9:33am
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I`ve just bought 2No led stop/tail that are fitted to the svx and 2No clear led indicators from somewhere else , went to fit the stop / tails today to find the the socket on the light for the plug is too large Evil or Very Mad i thought that by buying genuine lamps they were plug and play Rolling Eyes
Anyone know where i can get the correct plugs , and have the svx got a different loom or do they have adaptor leads.
Post #14959 2nd Sep 2009 7:24pm
nicks
the svx has link leads, so it uses original looms. i made the link leads my self - buying the plugs from Durite - it took a while to work out the colours, i still have them written down if any one wants them.
Post #15559 16th Sep 2009 4:55pm
Page 2 of 2 <12
