Home > Maintenance & Modifications > Help choosing rivet length
Rye54
Looking for a bit of help on what length rivets to buy to join 2 pieces of 2mm aluminium sheet together, there seems to be discrepancies between what various suppliers and guides recommend. I had originally planned to buy them based on the grip range of the rivet 4.8x10mm rivet with a grip range of 4-6mm, which according to one supplier was correct. However, having just checked online some websites recommend combined material thickness (4mm) + (1.5 x rivet diameter = 1.5x4.8 = 7.2mm) = 11.2mm meaning I would need a 4.8x16mm rivet with a grip range of 10-12mm.
Also, looking at aluminium case with stainless steel mandrel rivets, I assume they are widely used on aluminium body panels?
Any help would be greatly appreciated.
Post #901189 3rd May 2021 3:54pm
ickle
I was taught panel thickness plus 1.5 rivet diameter was correct for a normal 'pop' rivet.
Panel thickness plus 1x rivet diameter for a sealed 'Avdel' type
Normally disregard any allowance for sealer etc.
HTH Keith
Post #901228 3rd May 2021 7:41pm
