Home > Technical > Footwell repair panels with reinforcing ribs
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Has anyone found a supplier for OE spec defender footwells with reinforcing ribs?
YRM would be the obvious choice but their panels don't have the ribs, roversnorth sell some nice panels but importing repair sections from the US seems a bit backward.
I'm aware that most opt to replace with the YRM type smooth footwells but I only need to replace one and my OCD won't let me have one ribbed and one smooth footwell. Laughing 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #896362 7th Apr 2021 7:02am
Dinnu
I would definitely have the same problem. And when needed to make repairs for a friend, made sure to retain the ribs.
Can you try with these guys.. their illustration show that it is correct design:
https://www.pegasusparts.co.uk/ourshop_900...ender.html
I have not checked, as do not need, but will appreciate your feedback. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #896390 7th Apr 2021 8:23am
Dinnu
and according to product information:
IMPORTANT NOTE: Footwell panel has the 90/110 style footwell ribs. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #896391 7th Apr 2021 8:24am
Shroppy
Thanks Dinnu, unfortunately Pegasus parts have a pretty poor reputation (some people seem pleased but others received no parts or communication) so I'll avoid them. They are also very expensive compared to YRM, I think I may end up making my own repair panels for the few repairs I need to do to the outer footwells. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #896397 7th Apr 2021 8:36am
Eppilihp
Switzerland
Sorry for the stupid question, but why are there so many pre-drilled holes in all the footwell repair panels? Genuine water ingress feature, or ...?
Post #900522 29th Apr 2021 10:58am
Dinnu
There are quite a few holes on the original too.
Starting from bottom side, there are 2 or 3 square holes for the floorboard nut locking.
There are another 2 holes for the chassis bracker
Driver side have bonnet release cable hole
Driver side has 4 holes for steering column bracket
Further up there are 12 holes for clutch and brake pedal boxes plus an additional 4 or 6 holes for the gas pedal.
A few other holes for earths.
More holes for clips for brake pipes, harness, etc.
I have missed mentioning some other holes too. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #900591 29th Apr 2021 6:04pm
llessur
Would these be any good https://www.ebay.co.uk/itm/114786144168?ha...SwgrNgiq4n
just spotted them.
Post #900614 29th Apr 2021 7:54pm
nitram17
Post #900635 29th Apr 2021 10:25pm
Shroppy
Those look great llessur, I'll order a pair once my bulkhead has been dipped and I know the full extent of the corrosion. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #900650 30th Apr 2021 6:39am
nitram17
nitram17 wrote:
Try Here : https://yrmit.co.uk/product-category/land-...ender-110/
oops Embarassed sorry i did not read the first post properly!
Are those ribs just a design feature as they just look pressed into the steel and not reinforcing it ?your right though it would burst my melon to have one ribbed and one not.........
Post #900847 1st May 2021 10:31am
Dinnu
The ribs will stiffen the plate. So adding stiffness without adding weight. Although Landrover then spot weld another flat plate on top of it, effectively making a hollow section.. which further increase stiffness. Unlike the series, the footwells are structural, as they support the bulkhead fore/aft tilt (Series also had 3 ribs, different design, and no transverse rib).
Unfortunately having another plate spot welded on top make for a water trap and promote corrosion. But if I had to repair, I would want the ribs. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #900853 1st May 2021 11:21am
Co1
Depends on your welding skills, but you could spot weld the ribs on then tig braze the seam to make it a full sealed section to prevent/delay the corrosion.
Post #900922 1st May 2021 6:20pm
Dinnu
Brazing or additional welding other than spot welds will cause the footwell to warp. Not ideal in my opinion.
I chose to fill the cavities with wax while the bulkhead was suspended up side down. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #900930 1st May 2021 6:34pm
Co1
^^^ That’s a plan. Maybe Seam sealer as well.
Post #900950 1st May 2021 8:18pm
MichaelE
Doing some bedtime reading last night of a LR mag from last year, I saw a Britpart ad. They do some with ribs.
Post #901064 2nd May 2021 1:58pm
