- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Shroppy
Not a solution for everyone but I plan to add some holes to the top plate and potentially a drain hole in each of the ribs to enable galv to flow in and out of the closed section. I'll then probably fill the holes with mastic before paint. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
6th May 2021 8:06am |
