Home > Td5 > bulkhead/main and engine harness swap
benspray
United Kingdom 2006 Defender 130 Td5 HCPU Chawton White
Hi all
Anyone replaced the main/bulkhead harness and engine harness on a td5 Defender?
Just looking for a rough idea of how long its likely to take! and if there are any gotchas (like plugs that need de-pinning to fit through any holes etc)
swapping out my poverty spec looms for XS spec to add electrics/heated seats/air con etc.
Cheers all
Ben
Post #900360 28th Apr 2021 12:05pm
excossack
I am pretty sure that when my bulkhead was swapped the engine loom was disconnected and fed back via the main loom hole in the bulkhead. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #900364 28th Apr 2021 12:41pm
excossack
Maybe this helps
https://www.defender2.net/forum/topic49854...t=bulkhead 1999 Defender TD5 110
Regards
John M0VAZ
Post #900365 28th Apr 2021 12:43pm
rallysteve
Bulkhead loom doesnt require any de-pinning to remove/fit. From experience it is worth removing the cubby box/centre seatbox panel and the gearbox tunnel to give you access to feed the length that runs from the N/S of the bulkhead down to the ECU in the seatbox. You will need to take the whole dash off to do the swap. The worst bit of the bulkhead loom is trying to feed the wiring down the a-pillars and correctly insert the grommets.
Engine loom is a real faff to do with the wings and inlet manifold on, the glowplug connectors are very fragile and the alternator plug is a swine to get to/release.
Depending on your experience time will vary but personally i would probably take a couple of days to stripdown, swap both looms and refit dash etc. It will take longer if your tunnel screws are all rusty etc.
Dry silicone spray is well worth it for helping to ease the large grommets into the bulkhead and seatbox. Dont be tempted to try and force the Sumitomo multi connectors apart/together. They are easily damaged and pins bent. It is worth doing a like for like comparison when you have the old loom off to make sure any grommets/clips etc are swapped over. If you have any damaged connector shells most of the connectors are relatively easy to de-pin.
Let me know if you need any more info.
Cheers,
Post #900381 28th Apr 2021 3:46pm
benspray
Cheers Steve 👍
I'm doing a refurb on the new loom at the mo swapping out some broken shells etc and running wiring for the rev counter etc Smile
Just not looking forward to the swap Wink
Ben
Post #900384 28th Apr 2021 3:55pm
rallysteve
Sounds good, i started with a semi basic loom and added a load of ancillary wiring for my additional lighting, heated seats, heated screen, split charging and centre HMI so went through a similar exercise myself.
Also started with a TD5 bulkhead loom and stripped/modified it for my v8 project.
Depending in what year your base vehicle and new loom are you might find that you need to add the cable for the water in fuel sensor. My 02' loom had it but the 05' loom I used didnt and hadnt realised until it was too late! Rolling Eyes
Post #900405 28th Apr 2021 5:30pm
benspray
Cheers Steve,
I got lucky in that the new loom date is within a month of my old one so everything should just work 🤞
Trying to work out cruise control at the mo then I have heated mirrors with puddle lamps in the arms to run wires for then hopefully it's ready to swap.
Engine loom doesn't appear to need any work
I need to peg board it like you have, it's not good working on the floor.....
Ben
Post #900406 28th Apr 2021 5:41pm
