Home > Puma (Tdci) > Another starting problem.
Rescue01
My 2011 2.4 has had a intermittent starting fault for a few years but not enough to bother me till know.
The symptoms are that it cranks fine but won’t fire. I’ve noticed when this occurs the temp gauge shoots up to red when cranking.Also if the battery voltage drops a bit it’s not keen to fire. Battery good connections good. I can try it a few times then it starts fine.
Any suggestions from the wise?
This is another topic I will start a thread for but I need to get a fault code reader to check if any codes are registered so I will be looking for suggestions up to £300???
Right off to work if Tigger starts Laughing will check in later. Thumbs Up
Post #900306 28th Apr 2021 3:53am
Fabio
Portugal 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Morning,
It is a relay under the drivers seat. I think it is the second from last.
I cleaned mine and it has been fine ever since.
Fabio
Post #900310 28th Apr 2021 4:57am
