Home > Technical > Gluing vent seals to bulkhead
Dinnu
I have attempted to glue the vent seals (old style seals) to the bulkhead but result was a fail. I used a contact cement, one that comes in a yellow/black package, but it failed to grip to the rubber. Very good bond to the paint however.
Before I try again (as it was a pain to remove the glue from the bulkhead again) are there any good tips? Perhaps alternative glues? And as important, where did Landrover apply the glue to the seal? All the way inside where the spot welds in the bulkhead are, and the 2 ridges on the rubber or further out? Below is a picture of the contact points of the new seal.
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #899961 25th Apr 2021 6:16pm
L90Andy
United Kingdom 1997 Defender 90 300 Tdi ST Nato Green
Sorry can't help but watching with interest as about to do this on mine. As a back up I've got the foam seals which stick on the flaps instead, but I'd like it to be correct.
Good luck! Instagram: L90andy
My 1984 Ninety: http://www.defender2.net/forum/topic56071.html - SOLD!
My 2015 Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
Post #899968 25th Apr 2021 7:49pm
Dinnu
The foam seals are easier to install, as they come ready with double sided tape. The rubber ones not.
I have read online mixed opinions of which is better for sealing, and keeping water out.. for me the old rubber seals worked fine, and want period correct seals.
I did remove the old ones out long time ago, when I did some repairs. and I am sure that I used contact cement back them to re glue them. They were starting to come off, and the flaps were holing them in place, but that was after very long time!
One gluing method I am considering is polyurethane.. but I do not know if it is too strong.. in case one day I need to take the rubber seals off again.
I make a cross section, and indicated sides A, B, C and D, incase someone can suggest where to apply the glue Smile
Note that today attempt was on side A only - my thinking about keeping the water as far away from getting in as possible.
Post #899973 25th Apr 2021 8:06pm
donmacn
When I replaced my bulkhead, I used foam seals. I've no recollection whther I used the orignal tape glue, or something else.
I think the most common issue that leads to these seals leaking is corrosion in the 'hinge pins'. Once they stop moving easily you have to push harder on the vent lever, and the vent flap itself starts to bend. Once it's bent, you'll never get a good seal.
I think that you need to be sure your vent flaps are as close to flat/level as possible; to use greased stainless vent pins; and to use new foam seals. It's worked for me. Bulkhead vents are dry for the last 10 years. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #899986 25th Apr 2021 10:02pm
Dinnu
Good tip there Donmacm.
I read some reviews on 3m weatherstrip adhesive, and looks like good stuff.
In the absence of any advise where to apply glue, I will probably apply glue to points B and C. But will wait until the dash is back in place so I can pull the flaps tight against the seal while the glue fully cures. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #900119 26th Apr 2021 7:44pm
Steve_overland
United Kingdom 1997 Defender 110 300 Tdi HT Chawton White
I had these rubber seals on my 110 300 tdi, but they seemed to make it worse and started whistling so switched back to foam ones... problem solved..... @steve_overland on Insta.
110 expedition vehicle with pop roof
Post #900194 27th Apr 2021 11:43am
Pace
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
I found they were too tight on the flaps when closed as they are a significant thickness and created a worse seal at the bottom edge.
Tigerseal would glue them just fine, I don't think they're worth it though.
Post #900253 27th Apr 2021 6:05pm
Dinnu
Thank you for your replies.
What I did notice is that the earlier 90/110/Defenders and the later Defenders have a different design for the hinge plate that is spot welded to the flap itsef. On the earlier design it looks like it has a 'spring' to the hinge plate while the later ones was more solid. Perhaps it is one of the cause why the rubber seal works for some but not for others.
Thumbs Up for the tigerseal. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #900262 27th Apr 2021 6:52pm
Dinnu
Ok, quick update. I used a PU adhesive / sealant. Ran a very small bead of the adhesive around the the outer corner of the bulkhead, placed the seal, installed the vents and closed the vents shut as hard as I could possibly shut them without breaking anything for a few days. They seem to have stuck really well. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #905920 1st Jun 2021 6:52am
