![]() | Home > Td5 > TD5 fuel pump rebuild with replacement VDO pump |
Excellent. Thanks Dorsetsmith. Have pondered on doing this before. So that all comes to about £100 and probably a much better idea than buying a cheap OEM part
MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 137 ![]() ![]() |
hi,
in the process of stripping down the pump as I have come across many continental VDO motors on ebay for around £160 I am stuck at the green hose. I will continue tomorrow. I cannot open the pictures but It is nice to know that it can actually be done ![]() joseph |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
You can use side cutter or cv boot pliers if you’re careful.
These type will work https://www.amazon.co.uk/QWORK-Pliers-Clic...mp;sr=8-43 |
Hello the clamp was removed the hose was still tight.
Is it ok to use a regular s/s clip instead of the ear clips? |
I’d use the ear clamps, they’re not hard to get, most motor factors would have them. No moving parts and tight seal.
